Toto Drake Elongated vs Round in small space
Discussion in 'Toilet Forum discussions' started by dbill, Nov 25, 2012.
  1. dbill
    dbill New Member
    Nov 23, 2012
    St Paul, MN
    Hi all - As part of our bathroom remodel, I'm replacing our ancient Kohler low rider toilet with the Toto Drake CST454CEFG. As you can see from the picture, the current toilet front edge protrudes a bit into the door opening space and just grazes the door as it swings in.
    I'm changing the door to a pocket door, but do I still have a concern with passing inspection if the Drake still sticks out? Distance from the doorway to the toilet center line is 20" in from the door opening, and the door is 28" wide. 20" in from the door, the elongated bowl of the Drake will stick out 1-1.5" into the door opening. This seems like it would be ok for walking past, especially with the pocket door - but maybe we're just used to sidestepping this monolithic Kohler.
    Would this pass inspection? Or should I switch to the round bowl Drake? I'd really like to stick with the elongated bowl, but not if there's a code concern.
    Thanks-
  2. jadnashua
    Code requires 15" either side of the centerline of the toilet and 24" in front. It doesn't directly address any intrusion into the door space (that I know of, but that's definately not conclusive!).
  4. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    The CST454CEFG is the Drake II. It only comes in elongated. The CST743S or CST743E are the 1.6gpf and 1.28gpf round-bowl original Drakes, respectively. CST744S and CST744E are the elongated original Drakes.
    The model number you named is a nice toilet, with eco-flush (1.28), dual-cyclone flush, sanagloss, and Universal Height, all included.
  5. wptski
    wptski Retired Machine Repairman
    Oct 20, 2012
    Warren, MI
    That picture is a bit distorted but I'm guessing that there isn't 15" to the wall. That can't apply to exsisting structures?
  6. jadnashua
    FWIW IMHO, a typical elongated toilet seems smaller in a room verses a round one because it is smaller across at the front. ANy male in the house will appreciate it, and many women, too.
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Your space between the toilet and wall does appear to be less than code required 15", but that's what you have to work with. It might be wise to discuss this with your local inspector to see if this could be grandfathered. As noted, the slight extra space in front of the toilet will not really be a problem, so do go with the elongated bowl.
  8. wptski
    Oct 20, 2012
    Warren, MI
    Have you ever seen a situation where a local inspector didn't allow it to be grandfathered as codes may have changed over the years?
  9. Gary Swart
    Sep 1, 2004
    Yakima WA
    Please note that I stated you should check with your local inspector to see if this width problem can be grandfathered. If it can not, then you have a whole new problem. Obviously the existing toilet has be functioning for years at this width, but code does require 15" from toilet center to walls. You photo doesn't give a good perspective, so you should measure and see just what you really have.
  10. stephenk
    stephenk Member
    Nov 18, 2012
    Plains
    To the OP-
    I would recommend you look into what codes your city uses and which code your bathroom would fall under. People here are talking about 24" clearances required in front of the toilet. My community still uses the 2009 International Residential Code for home bathrooms, which only requires a 21" clearance in front of a toilet. I dug up this picture from a website that makes the 2009 IRC available online.
    Note - I'm no code expert, so contact your local officials for the final word.
Similar Threads: Toto Drake
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Yesterday at 9:06 PM
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions My Toto Drake, Flush Handle & Flapper Issue Jan 14, 2017
Toilet Forum discussions Toto Eco Drake vs Kohler Wellworth vs AS Champion Pro Jan 1, 2017
Toilet Forum discussions Alternate Tank Lid for Toto Drake 1.6gpm Toilet Dec 31, 2016
