Toto Drake CST744 on an 11" rough
The spec sheet here https://terrylove.com/pdf/cst744sg-specs.pdf shows 1-1/8" behind the toilet to the wall, and, you can generally fudge the toilet slightly forward on the flange with the slop in the mounting holes of the toilet and the closet bolts at least 1/4" while the outlet is still fully within the throat of the flange, so yes, it should work. You'll want to ensure you get the tank on straight and not tipping backwards.
TOTO Drake CST744S
Picture added by Terry
