Toto Dalton toilet review, owner comments and pictures
Discussion in 'Toilet Forum discussions' started by Perfectionist, Mar 29, 2007.
  1. Perfectionist
    Perfectionist New Member
    Mar 12, 2007
    Montreal Canada
    [​IMG]
    Dalton with very wide floor molding behind the bowl.
    Hi all,
    Any owner or plumber feedback?
    - Is it good, despite it's "only" a Gravity model? It's on Terry's list, though...
    - Does it have good bowl wash?
    - How about splashing?
    - Could it accomodate a baseboard that is 3 inches thick and 6 inches high, below its tank?
    The latter measures are not shown on http://www.totousa.com/admin/upload/pdfspc/s-734f-0302.pdf. It seems to be the case, but we have to be 100% sure prior to ordering it...
    Thank you very much!
    P.S. I've started a thread about the baseboard problem, but the names of the two toilets I would like feedback on are burried into it... Sorry for the overlap! I started these two extra thread since we have to order our toilet real soon since it might take up to 6 weeks to receive one. Plus it might be good for other members or surfers to see threads that are specific to these models. Well hopefully so! ;)
  2. jadnashua
    rather that repeat ourselves...just do a search...lots of comments on Drakes - nearly all good. Look in the blue bar above for the search function.
  4. Perfectionist
    Mar 12, 2007
    Montreal Canada
    Searching in the forum
    jadnashua, you're right, I forgot to search for "dalton" (not "drake") !
    Shame on me, especially since I usually search like crazy.
    Thanks for your reminder!
  5. Perfectionist
    Mar 12, 2007
    Montreal Canada
    Search results
    Here are some comments about the Toto Dalton, that I have found on this forum.
    1) Is it good?
    Very good, it seems so:
    - "The Dalton is a good value for the money, better than Cimarron and Champion for what it does."
    - "it is fantastic"
    - "has a conventional flush valve and works MUCH better than the Champion."
    - "I have actually been putting some extra wads of TP in to see if I can slow it down................ It just "laughs" at me and gobbles it down!!"
    - "You can't go wrong with the Toto Drake and a few others, Caroma, Aquia, Ultramax, Dalton, Gerber Ultraflush"
    - Dalton vs. Eljer Titan: "There are quite a few in the Toto line that I would prefer installing. …If you can find the elongated version of the Toto Dalton, that would work fine too."
    - "The flush is, indeed, great; I have no complaints whatsoever. It is much better than the 3.5 gpf I had."
    - "doesn’t clog at all"
    - "semi-high performance flush"
    - "Pure Flushing Performance (best to good): AS Champion, Drake, Dalton"
    - "competes well with the Eljer Titan"
    2) Does it have good bowl wash?
    OK, but not the best, I might say:
    - "rinses well"
    - "It has good bowl rinse too."
    - "Even though the Dalton is fairly thin on wash, it's an improvement over the Cimarron."
    - "... it seems the water sits too low in bowl which allows tp to settle on the bowl sides, sometimes have to double flush to remove sticking tp from sides, but otherwise very good"
    - "The Drake edges out the Dalton in clearing the bowl."
    Drake Pepper Test
    - "... rinse is straight down"
    - "I would rate the Dalton's wash as poor"
    Snowman's trick re Dalton bowl wash:
    http://www.terrylove.com/forums/showpost.php?p=11229&postcount=6
    3) How about splashing?
    - Toto toilets splash: "The CST703 through CST714 have shallow bowls and use the "wash down" flush. They work well, but have more splash than I like...
    The Dalton does not splash. The Dalton with the 2" flush valve has a deeper bowl too. CST733F"
    The new Promenade toilets CST424SF and CST424EF do not splash either.
    Another one to mention would be the Toto Dalton, good performance and good bowl."
    4) Could it accomodate a baseboard that is 3 inches thick and 6 inches high, below its tank?
    - "A heater behind the toilet? You might try the Gerber 21-318
    or Toto Dalton CST734F"
    OTHER
    - "It’s quiet"
    - "Quality of Product (flush noise, fill noise, assembly): Drake, Dalton, As Champion"
    - "... the pull on the leaver is almost instant flush / gone and the tank fills up again..."
  6. rosy
    rosy New Member
    May 14, 2007
    Toto Dalton
    Had this toilet installed a month ago. The Good: Very quiet for master bath, is ADA for my bad knees, Depth is only 26" which is very hard to find for an ADA round toilet seat.
  7. Perfectionist
    Mar 12, 2007
    Montreal Canada
    Thanks Rosy!
    We finally picked the Drake. We decided to get rid of the electric baseboard below the tank. I hope that we will like our Toto seat a bit more than you have! Good luck with the other seats that you'll try.
  8. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    a body gets used to any toilet seat. They are all rounded and smoothed edges.
    A body gets used to pretty much anything, except a pebble in your shoe.
    david
  9. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    Just had a call from a customer about the Carusoe splashing, they called Toto and they said replace it with a Dalton.
    Also found out you can use a Carusoe tank on a Dalton bowl.
    This is good because Carusoe makes a lined tank and Dalton does not.
    So you can now have a "Comfort Height" bowl and a Lined tank.
  10. cpqal
    cpqal New Member
    Sep 22, 2007
    Great Toilet Over All
    I installed a regular length ADA height Dalton by myself back in June of this year. I am very satisfied with it. As to your questions:
    -Is it good, despite it's "only" a Gravity model?
    I love it. I continue to be amazed at how it can evacuate everything in the bowl so quick with so little water, and I am a big guy.
    There is no swirling action but in 3 months it has never clogged and I have only used a brush once. I did wax the inside of the bowl before installing so I don't know how much a difference that might be making for awhile.
    I have not noticed any splashing at all.
    - Could it accommodate a baseboard that is 3 inches thick and 6 inches high, below its tank?
    Wow, that is some baseboard! I put a rule to mine and don't believe you would have a problem.
    [​IMG]
  11. nnotsoo
    nnotsoo New Member
    Feb 11, 2008
    undecided
    north of the CA border
    Dalton vs Drake = a stripped V8 vs a loaded V8!
    Dalton is a low end ADA. You get less for the $$, spend the extra, get a Drake 1.6 or 1.2, with G-Max/E-Max- (same thing) and if you can spend the extra get the Drake in Sana-Gloss, and FEEL THE DIFFERENCE!!
    Greg S:)
    Dixieline - Pro-Build
  12. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Wow, lol, I think the toto sof close seats are actually the most comfortable seats that I have ever sat on. And the soft close feature is totally outweighs any negative points a person might have with the seat. But that's just my opinion, I just didn't think someone would object so strongly to these seats! :)
  13. ralphbou
    ralphbou New Member
    Jan 23, 2010
    Miami, FL
    new dalton
    I installed a DALTON yesterday and gave it a good load, the Dalton flushed it quietly and with authority this is a very good john. Look nicer installed then in picture.I did not find any thing wrong with the seat, feel solid and the closing mechanism feel superior to every one I tried in stores.A very Happy owner
  14. DIY Duder
    DIY Duder New Member
    Nov 20, 2009
    Chicago
    I found a brand new Dalton ADA on craigslist for $50 so I figured I couldn't go wrong. Well, I didn't. :) I also put an AS champion 4 in my other bathroom too. That's about the extent of my toilet installation expertise! lol The installation was a little easier on the Dalton. So far no problems or clogs and I have tried to clog it with some excessive amounts of TP without getting it to clog. Good looking little toilet too! The only thing is it seems like, from what I here, the Drake is not that much more, less then 100bucks more and has a lot more power. If I were paying full price, it seems to me like buying coffee at 7/11, you may not need the extra 8oz’s more, but it’s only another 20cents and maybe you’ll want it. (Dalton 150/Drake 240 from Terry) But if you do really want to keep the costs down, it’s been great so far.
  15. RonB-Chicago
    RonB-Chicago New Member
    Mar 24, 2010
    Chicago
    Dalton Insulated Tank Question
    I'm looking to install a Dalton toilet with an insulated tank. (require the tall and smaller round depth dimension of the Dalton bowl) Humidity causes condensation. I believe I read somewhere on Terry's forums where a fellow installed a Carusoe (insulated) tank on his Dalton bowl. I'm wondering where this fellow learned about making this switch? I'm wondering if it worked out OK? I'm wondering if Toto informed this fellow of this option, as you purchase toilets by tank numbers and bowl numbers. I'm wondeng if anyone else has tried this type installation, or knows anything about doing something like this?
  16. jadnashua
    If you are replacing an old many gallon toilet with a new, 1.6g toilet, you may not get condensation. It is possible if you have repeated flushes, though. These newer toilets do not use all the water in the tan, so depending on how long it has been sitting there, that warmer water will mix with the incoming colder water and often will stay above the dew point. But if multiple people use it in a row, it would end up with all cold in there, and that could cause condensation. Also, with the low volume of water needed to refill, the water in the lines is likely much warmer than it would be if you were trying to refill a 5-7 gallon tank. For many people, it is a non-issue. Other than an insulated tank, which still could get damp if flushed numerous times in a row, addiing a tempering valve to warm the water always works and may be an alternative over buying a new tank.
  17. RonB-Chicago
    Mar 24, 2010
    Chicago
    Thanks for the quick reply Jim. This is a very good point. My old toilet is a Kohler that I installed in about 1980. It uses about 4 gallons per flush, and does nearly use all the water in the tank per every flush. Here in Chicago, the temp and humidity can swing a lot in just a few days. So air con does not come on until the weather finally settles down. This Kohler sweats easily under these conditions. I did my own tank insulation years ago, and it worked great. If the water does not totally empty the new Dalton tank, I might be OK. I will be installing the new Dalton in about 2 weeks. I just noticed that another fellow purchased a different tank for his Dalton that had the insulation.
  18. Terry
    Aug 17, 2004
    Most new toilets only use a little water in the tank.
    I doubt with only 1.6 gallons leaving the tank, that condensation would be an issue.
Similar Threads: Toto Dalton
Toilet Forum discussions Toto Dalton question Apr 15, 2013
Toilet Forum discussions Toto Dalton flushing problem? (video) Feb 22, 2012
Toilet Forum discussions Toto Dalton Toilet Aug 15, 2010
Toilet Forum discussions No fill tube to overflow on Toto Dalton Jan 18, 2010
Toilet Forum discussions Fluidmaster Toilet Bowl Cleaning System in Toto Dalton? Nov 23, 2009
