Toto CST743E noise when flush starts and stops
Discussion in 'Toilet Forum discussions' started by kevintoto, Nov 8, 2009.
  1. kevintoto
    kevintoto New Member
    Nov 8, 2009
    Northwest
    I installed a CST743E myself and it's much better than the 14 years old toilet it replaces. But it wouldn't be a fun DIY if everything is perfect, would it?
    After pushing the flush lever, there is a short sucking sound. The same sound happens again when the flush is done and is a little louder. I'm guess it's the flush valve but it's brand new so it shouldn't be defective. I've also tried to adjust the supply line valve and the water level screw but they didn't make any difference. Is it because the water pressure is too high?
    Do anyone else with 743E have similar problem? Thanks,
    Kevin
  2. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    I've not noticed this in my three CST743E's, but I'm not sure what you mean by the sound.
    Which fill valve arrangement do you have: Type A or Type B (see the manual, page 4 for a diagram.) If you were able to adjust level easily without removing a white tamper key, then you must have the A which is a screw type adjustment.
    Where is the sound coming from: Bowl? Tank? Fill valve? Flush valve?
    You could probably determine whether or not it is fill valve related by shutting off the water supply to the toilet, then flushing. If you didn't hear it then that would mean the sound was coming from the fill valve. When you say the water pressure is high, how high?
  4. Terry
    Aug 17, 2004
Similar Threads: Toto CST743E
Toilet Forum discussions My Toto CST743E Toilet is slowly flushing less and less properly Sep 28, 2016
Toilet Forum discussions Will a Toto Drake CST743E fit my 10 3/4" rough-in? Jan 27, 2015
Toilet Forum discussions TOTO: what is the standard tankl for a CST743E bowl? Feb 21, 2012
Toilet Forum discussions Closet Flange Mounting Bolts and Wax Ring for Toto CST743E Jul 29, 2010
Toilet Forum discussions Verifying the right Toto EcoDrake bowl to go with the CST743E tank Jan 29, 2010
