TOTO Carlyle - flushometer replacement?
Discussion in 'Toilet Forum discussions' started by NYChomebuyer, Feb 25, 2006.
  1. NYChomebuyer
    NYChomebuyer New Member
    Feb 21, 2006
    New York, NY
    Does anyone know if a TOTO Carlyle is a viable alternative to an already installed flushometer toilet? given the proper fittings have been installed. thanks.
    Performance is very good on the Carlyle
    Terry Love
  2. Given the reworking of the plumbing for the water supply that you will encounter switching to a "conventional" tank-type toilet, your options as to which brand/model you switch to are pretty much wide open provided the rough-in for the drain is the same. Rough-in is the distance from the center of the drain to the finished wall. If measuring with the toilet in place, measure from the bolts that hold the toilet bowl to the floor back to the finished wall. The most common rough-in is 12 inches, although there are also 10 and 14 inch installations. Many manufacturers offer their standard models in all three sizes. Toto has several models which can be adapted to variable-sized rough-ins with an appropriately sized Unifit adaptor and Niagara's Flapperless model has flexibility in the tank installation to allow for 10- or 12-inch rough-in.
    Considering that the correct plumbing is already in place, I personally would stay with the Flush-o-meter. They appear to be less prone to clogging due to the increased water pressure in the flush. In this case, I would be willing to allow functionality to override my fashion sense in terms of how it looks.
  4. jimbo
    jimbo Plumber
Similar Threads: TOTO Carlyle
Toilet Forum discussions Maintenance on Skirted Toilets like Toto Carlyle II Sep 17, 2015
Toilet Forum discussions Toto Carlyle II very slow to fill up-need help Oct 2, 2014
Toilet Forum discussions Installing Toto Carlyle II - water supply Aug 13, 2013
Toilet Forum discussions Toto Carlyle II vs. Vespin II reviews? Feb 8, 2011
Toilet Forum discussions TOTO Vespin II Expectations vs TOTO Carlyle Jan 3, 2011
