TOTO Aquia, we have them in Seattle
Discussion in 'Toilet Forum discussions' started by Terry, Nov 6, 2007.
  1. Terry
    Aug 17, 2004
    We have plenty of TOTO Aquia toilets for the Seattle area now.
    We just picked up 40 of them.
    TOTO toilets in Seattle
  2. johnescu
    johnescu New Member
    Nov 6, 2007
    Aquia toilets
    Do you have performance / recommendation info on the Aquia EL (CST 414M)?
  4. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    CST414M: CT414 bowl, ST413M tank 800 on the MaP test
    Meets Los Angeles specification (SPS) for water savings sustainability
    Qualified to meet U.S. EPA WaterSense Specification
  5. johnescu
    johnescu New Member
    Nov 6, 2007
    Eco toilets
    Thanks, I was hoping for some plumber / consumer recommendations.
    I want to replace 2 toilets (one white, one biscuit, both elongated). I can get a rebate for using the high efficiency toilets.
    Is the EcoUltramax good?
    The Aquia is good looking, but I heard it is harder to install.
  6. jadnashua
    None of these toilets are hard to install, but some are different. Plumbers don't like different. You have to drill some additional holes to mount the adapter to the floor over a normal toilet. Also, the water supply might have to be moved over, since they have a skirt that is sometimes wider than standard. Since many installations are not standard in the first place, you may not have to move anything.
    Note, Toto makes many toilets that use standard installation that any generic toilet will fit, too.
  7. Terry
    Aug 17, 2004
    The Toto Aquia works very well, I had one installed in my home for two years. It does take a little more time to install.
    The Toto Eco Drake works well too. An easy installation.
  8. jcg1545
    jcg1545 New Member
    Nov 27, 2007
    Canada
    something to be aware of though
    if you are install an aquia in a visible area such as I was (pedestal sink, doorway facing entrance) the rough-in sticks out the back and is very visible
    had to return and now thinking of a carlyle as a substitute (wife wants skirted toilet)
  9. Archer
    Archer New Member
    Nov 29, 2007
    Condensation on Aquia Tank
    Have you seen problems with condensation on the Aquia? If so, is there an insulation kit to reduce the problem?
  10. Terry
    Aug 17, 2004
    There is no problem with condensation.
  11. jadnashua
    ANY toilet, even an insulated one, can have condensation on it if it is in a high use situation. The only way around that is live in a desert or put a mixer on it to warm the water up.
  12. dab2mi
    dab2mi New Member
    Dec 11, 2007
    I was wondering about that as well, I can see the plastic PVC sleeve from the side. Is that normal? Did I install that part wrong?
  13. Terry
    Aug 17, 2004
    [​IMG]
    You can see the end of the adapter on the Aquia, if you are looking from the side.
    If you are looking from this angle, it's hidden on the back side.
  14. dab2mi
    dab2mi New Member
    Dec 11, 2007
    Thanks alot.
Similar Threads: TOTO Aquia
Toilet Forum discussions Toto Aquia II (2 piece) vs Toto Vespin II (2 piece) Mar 15, 2017
Toilet Forum discussions Aquia wall-hung bowl, TOTO tank required? Feb 3, 2017
Toilet Forum discussions Rough in question for TOTO Aquia Oct 26, 2016
Toilet Forum discussions TOTO THU9090R adapter for installing a Washlet on an Aquia Oct 13, 2016
Toilet Forum discussions TOTO Aquia, Shut off Valve blocking Jun 28, 2016
