Toto Aquia vs. Aquia II vs. Aquia III
Discussion in 'Toilet Forum discussions' started by nonothing, Oct 24, 2011.
  1. nonothing
    nonothing New Member
    Oct 24, 2011
    idaho
    Greetings,
    Can't really tell the differences between these models, other than rough in options, height differences, and glaze options. The company has not been much help either from the website or emails. Anything relevant to its function, and/or its price?
    Also, what info would you want to give the contractor installing one of these for the first time?
  2. Terry
    Aug 17, 2004
    The Aquia 111 bowl is 1" higher then the Aquia II bowl.
    My son James did a nice set of instructions for the Aquia; which after we had dinner with Toto in the Summer of 2010, they did a "copy paste" of and modified their instructions with his corrections.
    Here are Jamie Love's instructions
  4. crcurtis
    crcurtis New Member
    Oct 25, 2011
    Vancouver, BC
    Problems with distance of Flange from wall for Aquia II
    My plumber just installed one of my many Toto Aquia II toilets and it is sticking out almost 3 3/4" at the tank. Obviously they installed the flange too far from the wall.
    I want to pull it back in but it appears that an offset flange or whatever will not work. This is from the plumber so I am sceptical since he messed it up in the first place.
    Any advice as I prefer to have the back of the Tank about 1" from the wall.
    Please help as I really do like the Toto Aquia toilet...
    Curtis
  5. jadnashua
    If the flange was exactly 12" from the finished wall, the toilet would have approximately 1/2" behind it. So it looks like it is close to 15+" from the wall. Unless you move the flange, not much you can do about it. One of the Toto's that use the UniFit adapters could move it back a couple of inches, but it would still be further from the wall than you want.
  6. crcurtis
    crcurtis New Member
    Oct 25, 2011
    Vancouver, BC
    He says it is 13" since that is what he usually allows for Kohler toilets...so either something is screwy or he has not installed it correctly. I guess I need to have him pull it and measure it myself.
    Does the Aquia II work with the Unifit Adapter?
  7. jadnashua
    If it was 13", at least based on the spec sheet (and on Toto, they're usually close), there should be about 1.5" behind it. No, the Aquia does not have various adapters...it only has one, and it is not the Unifit (which comes in 10, 12, and 14").
Similar Threads: Toto Aquia
Toilet Forum discussions Aquia wall-hung bowl, TOTO tank required? Feb 3, 2017
Toilet Forum discussions Rough in question for TOTO Aquia Oct 26, 2016
Toilet Forum discussions TOTO THU9090R adapter for installing a Washlet on an Aquia Oct 13, 2016
Toilet Forum discussions TOTO Aquia, Shut off Valve blocking Jun 28, 2016
Toilet Forum discussions Does Toto make a unifit adapter for Aquia? Mar 15, 2016
