Toto Aquia II with two 45 degree elbows and flange height???
Discussion in 'Toilet Forum discussions' started by Curtis Myers, Nov 25, 2012.
  1. Curtis Myers
    Curtis Myers New Member
    Nov 25, 2012
    Saskatchewan
    Hi - I'm installing a Toto Aquia II toilet in a washroom that I'm renovating and in order to position the toilet where I need it, I need to use two 45 degree elbows. (See picture.) I was going to use an offset toilet flange but this doesn't get me to where I need the toilet. It would work but it wouldn't be perfect. Will I have any issues with plugging/flushing with the two 45 elbows?
    Two other questions:
    1. Install instructions for the toilet state you can't use the toilet with a double sanitary tee / sanitary cross, and can only use the toilet with a double combination WYE / 1/8 bend. Is this true or simply a guideline??? Note: I'm going to have approximately 12" of horizontal pipe from toilet location to main stack.
    2. Toilet flange: I've read too many opinions on height of toilet flange: above, below, flush, etc. I'm going to settle with my flange flush to the top of tile and at most it will be 1/8" higher than tile (and likely 1/8" lower.) Note: I live in Canada and saw that someone mentioned code is in Canada is flush or an 1/8" above.
    Thank-you for your input,
  2. Terry
    Aug 17, 2004
    The two 45's are much better then using an offset flange.
    I wouldn't worry too much about the height. Do what you can, and the rest is taken care of by wax.
    The Aquia has a 2" flush valve. It isn't going to make that much difference on the cross. The toilets with a 3" flush valve are more of an issue. They flush with enough force to skip across the cross fittings and up the other side.
  4. Curtis Myers
    Nov 25, 2012
    Saskatchewan
    Thanks Terry! Exactly the answer I was hoping and expecting. Your forum is great and one that I've looked at many times. And if I lived in your hometown you would definitely be my plumber. Thanks again....Curtis.
  5. jadnashua
    Since this is apparantly all new, why not install the flange where it was designed to be -on TOP of the FINISHED floor? Yes, it will work elsewhere, but it is designed for one place. On retrofits, it often is ignored, and ends up lower than design because they don't want to move it, but you have the chance to do it right.
Similar Threads: Toto Aquia
Toilet Forum discussions Aquia wall-hung bowl, TOTO tank required? Feb 3, 2017
Toilet Forum discussions Rough in question for TOTO Aquia Oct 26, 2016
Toilet Forum discussions TOTO THU9090R adapter for installing a Washlet on an Aquia Oct 13, 2016
Toilet Forum discussions TOTO Aquia, Shut off Valve blocking Jun 28, 2016
Toilet Forum discussions Does Toto make a unifit adapter for Aquia? Mar 15, 2016
