ak212
I'm trying to install an Aquia II but am stuck at the tank-mounting stage.
The problem is that the mounting bolts (pointing up from the toilet bowl) do not protrude into the tank when I set the tank on the bowl.
Either the bolts are too short or the rubber gasket that goes on the bottom of the tank is too thick. (It seems really thick--the tank is not even close to flush with the toilet.) I'm using all of the standard install hardware that came with the toilet.
Has anyone had this problem?
Thanks,
AK
Thanks,
AK
