Toto Aquia gets top flush rating, Good Housekeeping Institute
Discussion in 'Toilet Forum discussions' started by Terry, Jun 2, 2008.
  1. Terry
    Aug 17, 2004
    Good Housekeeping Institute​
    For a quieter option, pick the gravity-fed, dual-flush Toto Aquia ($417.50). It has an extra-low 0.9-GPF small flush for liquid waste, and its 1.6-gallon full flush was tops in the Good Housekeeping Research Institute's clog tests.
    Gerber Ultra Dual-Flush ($367) took the top spot, with two pressure-assisted flush strengths. You push down for a smaller flush (1.1 GPF) or pull up for a larger one (1.6 GPF) if desired. But since the smaller one performed just as well as the large on all clog tests, Good Housekeeping recommends using the low exclusively, for even greater water savings. Pressure assistance uses a mechanism in the tank to propel water downward. It's usually most effective, but it can be noisier.
    The panel of experts rated the Kohler's Highline Comfort Height ($517) tops for appearance.
    Pictures below.
    The magazine also recommends the quieter, gravity-fed Toto 1.28-GPF Eco Drake ($318)
    The story and the video
    Toilet paper poll
    The Gerber with EcoFlush DF-21-318
  2. nnotsoo
    nnotsoo New Member
    Feb 11, 2008
    undecided
    north of the CA border
    New Aquia's to be released soon , I and II
    and what about the Toto Eco Gwyneth in Sanagloss??
    Rating?
    Customer had returned a MS974224CFG - Guinevereâ„¢ Toilet - SanaGloss, claimed to be too noisy. Must have been the water going through the "unifit". So Toto suggested to pack the skirted chamber with foam. Toto also said they are going to stop making the Unifit models and replace them with flow through china trapways.
  4. Terry
    Aug 17, 2004
    And yet I've sold dozens of the Soiree and the Guinevere toilets, most of the customers started with one or two, and then ordered more. One customer in Medina wound of with five Guineveres.
    I've had very good comments from the owners.
    You will always have customers that think water should move very quietly when flushed though.
    Kohler used to make a "very" quiet one about 30 years ago, it took 9.5 gallons to flush and required a 1/2" supply tube, not the 3/8" we now use.
  5. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    I have 3 Soiree's in my home and not sure where the noise problem would be, it flushes in about two seconds and refills in about 5 seconds and no noise.
    I have had complaints and have heard it myself, when you are adding liquids or solids to the bowl you can hear it dripping into the Uni-fit. As soon as you flush and it refills the noise stops.
    I have not heard about Toto stopping the Uni-fit rough-ins as a regular china trapway would limit the toilets to 12" rough-in's unless they produce 10's & 14" rough in toilets as well but i doubt they would do that.
    I haven't sold any Gwyneth's yet but i think they will be a big seller as they have everything you would want in a low flush toilet. Toto is also releasing the Gwyneth in two piece as well.
    [​IMG]
    TOTO Guinevere
  6. lisabee
    lisabee New Member
    Jun 14, 2008
    difference between aquia I & II?
  7. Terry
    Aug 17, 2004
    The Aquia I and the Aquia II will be very similar.
    I haven't installed a II at this point.
    Tank parts will be the same, the flange adapter is a little different on the II.
  8. lisabee
    lisabee New Member
    Jun 14, 2008
    thanks!
    thank you so much! now i just have to find a way to get one. the closest dealer (by a lot) is a to-the-trade-only place. hate that.
Similar Threads: Toto Aquia
Toilet Forum discussions Aquia wall-hung bowl, TOTO tank required? Feb 3, 2017
Toilet Forum discussions Rough in question for TOTO Aquia Oct 26, 2016
Toilet Forum discussions TOTO THU9090R adapter for installing a Washlet on an Aquia Oct 13, 2016
Toilet Forum discussions TOTO Aquia, Shut off Valve blocking Jun 28, 2016
Toilet Forum discussions Does Toto make a unifit adapter for Aquia? Mar 15, 2016
