Toto Aquia dual flush toilet product review, comments and posts.
Discussion in 'Toilet Forum discussions' started by stimpsonjcatt, Aug 31, 2005.
  1. Terry
    Aug 17, 2004
  2. arnsberg
    arnsberg New Member
    Jan 5, 2009
    Response to ---Urine smell from the Aquai Toto toliet
    Thank you for responding to my question. Your answer makes sense . I forgot
    to mention that our floor is like beach stones and I recollect that it was challenging to level the toliet . We had to put in a shim and then my husband caulked with silicone. Yes, I think there have been a few misses with urine.
    At least you have cleared up there being any issue with the toliet.
    Thank you.
    Arnsberg
  3. Newmark
    Newmark New Member
    Jan 19, 2009
    Problem with Aquia doing half-flush only?
    I have three Toto Aquias ( type I) in my home and they all do the .9 gallon half flush regardless of which button is pressed. All of them flushed fine after I installed them but after a few months they started doing this.
    When taking the lid off the tank, I see no problem with how the button pins align with the internal buttons on the flush tower (although they are a bit short as another person mentioned). If I operate the internal buttons without the lid on, sometimes it flushes properly. But sometimes not and I can see the blue cup rise in the flush tower when the full flush button is pressed and this is supposed to happen only for the half flush.
    When I remove the flush tower and fiddle with the buttons, both the stopper mechanisms seem to work just fine.
    We have very soft water here and there are no obvious mineral deposits.
    Anyone seen this problem?
    thanks
  4. justM
    justM New Member
    Mar 8, 2009
    I've got my Acquia II. I've taken out my old toilet (a first). I've tiled the bathroom (just vinyl tiles...the toilet took most of my budget...over concrete). I've been planning on having the plumber install the toilet. However, I'm not sure, having studied this thread, who has the advantage: me, who's studied this thread but never installed a toilet, or the plumber, who's installed thousands of toilets but never THIS kind of toilet. I did ask him about it. He said he'd heard good things. He said no problem, but he knew he was going to have to drill into the slab. It's not his favorite thing to do, but no problem.
    Honestly, that's the scariest thing to me...drilling into the slab. What if the holes aren't straight? What if they're off a bit?
    I think between the instructions, this thread, and general 'how to install a toilet' instructions, I'm pretty well off.
    I wish the instructions were Acquia II specific. I've gone through and crossed out the stuff pertaining to the A I.
    One other concern: the tank bolts.
    In post 37 of this thread, Terry said that they sand the inside of the tank where the bolts connect. Every time? And why? Make it rougher to get a better seal? Make it less thick?
    Others talk about tightening them...a lot. That scares me too. I don't want to break it. But I also don't want leaks.
    I'll probably fire away other questions/concerns. Any bits of advice or answers to the questions wedged into my post are appreciated.
    Complete Instructions for the Aquia written by Jamie
  5. jadnashua
    The porcelain after casting, will have a little roughness to it. Using some fine sandpaper will smooth it off, making it easier for the gasket to seal without undue pressure. This is true of any toilet...you probably don't need to do it, but it only takes 10-seconds, so why not?
    The Aquia comes with a template to show you where to drill your holes. It's not rocket science. A new, nice and sharp carbide drill bit should drill a clean hole fairly easily. One thing I've noticed is that the plastic inserts they include seem to be sized for metric holes, and the equivalent inch-size is slightly small. I've just picked up some made for inch-size. Your results may differ...I haven't installed one for awhile, so don't know if that was a one-time or long-term situation. A hammer drill makes holes in concrete easier, but for 4-holes, not worth the expense unless you will have a use for it later...more tools are always nice! A regular one will work, especially with a new bit. Vacuum out the debris from the hole before you try to insert the fastener.
  6. justM
    justM New Member
    Mar 8, 2009
    Thanks. I just wanted to know why. I'd feel better doing it now.
    My house is made of block/brick. This would probably be the perfect excuse to get a hammer drill...but I think I'll just get a nice new bit. The vacuuming is a good tip.
    Thanks again.
  7. JIMANDTHOM
    JIMANDTHOM New Member
    Feb 28, 2009
    So far we are very happy with the aquia
    Installed an aquia ii the last weekend in february, in the main bath, and unless the the performance starts to "crap" out another will be installed in our 3/4 bath this summer or fall. The installation over vinyl went very well, no runs, no drips etc... Took about 2 hours as i kept reading the instructions and checked everything many times before going to the next step. We have had no issue with "marking", but varing degrees of digestive health could have a bearing on this. A big test on this will be when my brother comes for a visit. We swapped out on old 1940s crane that was a +3 gallon flusher and estimate a 12-15ooo gallon saving yearly on our water bill plus a savings on our sewer bill. While i realize the next install on concrete floor may be more of a challenge i would rate this toilet as moderatly easy to install-looks and performs well and would not hesitate to recommend this unit based on this short period of use.
  8. jzsjr
    jzsjr New Member
    Apr 1, 2008
    looking at Aquia II
    I'm trying to figure out if the Aquia II will fit in my space. The rough in is the required 12 inches but The plumbing comes up through the floor and not the wall. I had to re-do it this way when a nipple broke on me. Thus the plumbing through the floor is about 3 inches off the wall measured to the furthest edge of the escutchen (sp) and is 2 3/4 inches to the nearest edge of the escutchen from the center of the toilet. If this is too vague perhaps I can attach a picture later. I'm worried that since the Aquia toliet bases run very close to the wall the plumbing will be in the way.
    thanks,
    Jim
  9. jzsjr
    jzsjr New Member
    Apr 1, 2008
    Aquia II installation
    I went ahead and bought the Aquia II and installed it yesterday. There was enough room for the water line that comes up through the floor partially behind the toilet. It is a very nice looking and working toilet. It is also my third (different) toto completing my three bathrooms (thanks to Terry's web site). My advice is to use the link on Terry's responses to Jamie's installation instructions. The part about drilling the white anchors with the 3/16 inch bit is very helpful (always good to switch to a normal wood bit and not use a masonary bit). When drilling on tile I've found it necessary to tap the tile with a nail punch or the bit itself to score the tile so the bit does not walk all over the place. I also thought I would pass on that it is better to use wax to lube screw threads than soap.
    thanks,
    Jim
    [​IMG]
  10. justM
    justM New Member
    Mar 8, 2009
    I had the plumber do it. I needed some other things done, they were going to be here...I just let them do it.
    I really wanted to be here, but couldn't coordinate the schedule of when I was available and when they were. This was probably for the best because I'm sure I would have been hovering.
    I'm very happy with it so far.
    I'm not sure that the level is set properly for the smaller flush...I don't see a whole lot of difference between the two. (But I'm coming from a 3+gallon flush...so they're both a lot different than that.) I'm going to investigate this weekend.
    Thanks to all here.
  11. Reader Review
    Reader Review Comments by readers
    Jan 2, 2006
    Thank you! I already am really happy with my new toilet and washlet seat.
    -Ann T
    Seattle WA
    Toto Aquia CST464MF with SW554 Washlet
    [​IMG]
  12. Terry
    Aug 17, 2004
    [​IMG]
    TOTO CST416M
  13. ahr2000
    ahr2000 New Member
    May 26, 2009
    Aquia II re-installation question
    I've read through the Aquia thread but didn't find an answer to the exact question I have.
    I recently removed my Aquia II so I could paint the wall behind it. To remove the toilet I removed the setting bolts and then just pulled the toilet up. It came out extremely easily and cleanly. The bottom of the trapway just popped off the gasket at the outlet flange. So my question is: when I re-install the toilet, can I just set it back on the gasket and bolt it back down, or do I have to remove the outlet flange and put in a new wax ring below?
    If it's not obvious, I had a plumber install the toilet so I'm not sure about the proceedure to put it back. From what I"ve been told, you always have to put a new wax ring on, but when I removed this toilet, the connection at the outlet flange seemed so clean, and the wax ring is underneath the flange (which I didn't remove) that I'm wondering if it needs a new wax ring.
  14. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    If you didn't remove the Unifit rough from the floor, then you do not need to do anything just push the toilet back into the gasket.
  15. Peanut9199
    Apr 23, 2007
    Ontario, Canada
    Attached picture of installation
  16. ahr2000
    ahr2000 New Member
    May 26, 2009
    Great -that's the answer I was hoping for!
    THanks.
  17. yserra
    yserra New Member
    May 27, 2009
    what about using a waxless ring with Toto's dual flush toilets?
    We just bought two dual flush toilets and, not having seen the bottom side of the toilet, went ahead and bought two waxless rings to install them. Now that I have seen the system Toto uses I'm wondering if it is possible to use the waxless ring? Anyone done this? How?
  18. Terry
    Aug 17, 2004
    The Waxless seal should work too.
  19. yserra
    yserra New Member
    May 27, 2009
    need more info
    How will the waxless work? Do we just bolt the gray plastic plate from Toto to the floor over the waxless insert and then place the bowl over that? We are having a hard time understanding how the red gasket on the waxless system will seal to the gray part from Toto. Are you sure this will work??
    Y.
  20. metropxp
    metropxp New Member
    May 28, 2009
    New Jersey
    Fill valve issue --toilet is running
    We had two Toto Aquia installed 1 1/2 years ago. Now one is constantly running. I followed the procedures for cleaning the flush valve and fill valve, but it seems to be an issue with the float not shutting off the water.
    Is there something else I should try before just replacing the fill valve?
Similar Threads: Toto Aquia
Toilet Forum discussions Toto Aquia II (2 piece) vs Toto Vespin II (2 piece) Mar 15, 2017
Toilet Forum discussions Aquia wall-hung bowl, TOTO tank required? Feb 3, 2017
Toilet Forum discussions Rough in question for TOTO Aquia Oct 26, 2016
Toilet Forum discussions TOTO THU9090R adapter for installing a Washlet on an Aquia Oct 13, 2016
Toilet Forum discussions TOTO Aquia, Shut off Valve blocking Jun 28, 2016
