Toto Aquia dual flush toilet product review, comments and posts.
Discussion in 'Toilet Forum discussions' started by stimpsonjcatt, Aug 31, 2005.
  1. Terry
    Aug 17, 2004
    CST414M is a 15-1/8" high bowl using the more complicated floor mounting, with an open back bowl.
    CST416M is a 15-1/8" high bowl with the less complicated floor mounting, the back of the bowl is closed.
    CST464MF is a 16-1/8" high bowl, otherwise like the CST416M
    CST421MF is a 16-1/8" high bowl, otherwise like the CST416M
    M = dual Max flushing
    F = 16-1/8" high bowl
  2. jenny123
    jenny123 New Member
    Oct 28, 2010
    florida
    Which is better?
    Hi,
    I never thought I would spend so much time researching toilets. I am stuck between Toto's Aquia and Kholer's Strela. I am not sure which toilet is better. Could you please advise? Also, what is the difference between the Toto's CST412MF and CST464MF? These toilets are the same price.
    Thanks for your help in advance.
  3. mdenato
    mdenato New Member
    Nov 4, 2010
    Des Moines, IA
    I've installed my new Aquai ... almost... I'm about 1/2" from the bowl being pushed back to where it's supposed to set. On one side I can screw in the mounting bolt, but not the other - so I'm thinking it's off a bit, but nonetheless I cannot push the bowl back any further. I measured everything and even soaped the ring as you suggested... The only thing I can think of is that the bowl is rubbing against the mounting blocks making it impossible to push it back any further. So, what do you suggest? Can I somehow trim the mounting block - rather than taking the whole thing back out and moving the blocks? That's the easiest option to me that I've thought of so far - but want to get advice from you before I try anything.
    Thank you -
    Michael
  4. Terry
    Aug 17, 2004
    The blocks are there to receive the attaching screws. I little triming shouldn't hurt.
    You must have the CST414M Aquia if you are sliding the bowl toward the wall into the adapter. How far from the wall was the rough-in?
  5. mdenato
    mdenato New Member
    Nov 4, 2010
    Des Moines, IA
    Okay, i'll try that.
    Yes, it's the cst414m and a 12" rough-in.
    thanks for the quick reply.
  6. TylerB
    TylerB New Member
    Nov 7, 2010
    Carolina
    Bowl drain
    I installed the Aquia II a few months ago thanks to this site! I am now noticing something unusual - after a flush the bowl empties and refills. Within a few hours though the bowl is back to almost empty like it is draining somewhere. There are no apparent leaks and it seems to flush with the same force as always. Any ideas as to where the water is going and how to stop it?
  7. Terry
    Aug 17, 2004
    There should be very little water in the bowl when at rest.
    Are you sure there isn't a plug somewhere, and that the bowl is being overfilled and then seeps down to it's natural level?
    [​IMG]
    The water level is at the second line starting from the middle.
  8. CapstanRec
    CapstanRec New Member
    Sep 28, 2010
    New Orleans
    I installed a Toto Aquia III this past Friday. It took me longer to read and understand the instructions than to actually do it. I installed a new brass nipple and 1/4 turn valve as well and the whole process just took a few hours. The extra flange and mounting hardware is a great idea so if the toilet has to be removed, the wax seal still remains intact... unlike a traditional toilet installation.
    And my girlfriend loves the soft close seat. She won't miss the toilet seat banging in the middle of the night. Ha.
    I'm considering replacing my upstairs toilet as well... but it might be a 10" rough in. I'll have to check.
    This place is a great resource! Thanks again.
  9. TylerB
    TylerB New Member
    Nov 7, 2010
    Carolina
    Thanks! The water level seems to be filling up to the level in your picture and then occasionally seeps down so it is just below the opening to the drain (does that make sense?). It doesn't happen with every flush and otherwise the toilet is functioning well.
  10. jadnashua
    Do you ever flush dental floss or hair down the toilet? On occasion, those strands can act like wicks and let water out. Also, if the toilet is not used for extended time, and the house is dry and or hot, you'll get some evaporation. But, if it drops to that low level regularly, and within hours, there may be something wrong.
    It could be as simple as the overflow hose is misplaced.
  11. Firemark
    Firemark New Member
    Aug 11, 2009
    Southern NJ
    I've experienced the same thing on one of two Aquia III's on rare occasions in the past year. My best guess is it's caused by my washer discharge that is within 5 ft. There's so little water in the bowl normally just a bit of suction will pull some out. Both the toilet and washer share the same vent stack. I haven't checked the vent stack for blockage.
  12. Terry
    Aug 17, 2004
    Or if you have back to back toilets, sometimes flushing the other toilet will cause some water to leave the bowl.
  13. nsx78
    nsx78 New Member
    Nov 9, 2010
    la
    Hello all, I would like to put in a toto aquia ii. I've read the rough in should be 12 inches. I just measured 11inches from the back wall to the center of the hole. Does this mean it won't fit? Thanks for your help.
  14. jadnashua
    Make sure you are measuring to the finished WALL, not the baseboard or trim, unless the trim is quite tall. The spec sheet showing dimensions is on the www.totousa.com website.
  15. jjustice
    jjustice New Member
    Nov 2, 2010
    retired
    Charlottesville, VA
    I want to replace two American Standard toilets with the Toto Aquia II. Will they fit?
  16. Terry
    Aug 17, 2004
    95% of all homes have a standard 12" rough-in. That's the distance between the back wall and the center of the drain.
    That normally is the center of first set of bolts that hold the bowl down.
    The Aquia needs 11-1/2" or more.
    Yeah, I'm 95% sure.
  17. jjustice
    jjustice New Member
    Nov 2, 2010
    retired
    Charlottesville, VA
    Great. thanks!
  18. mcdonaldb
    mcdonaldb New Member
    May 8, 2010
    Minnesota
    Toto aquia III install
    I'm in the process of finishing a new bathroom, i am just about to tile the bath floor and am interested in a Aquia III. I have seen the Install pdf from Toto's website but want to make sure im not missing something. I have never installed a toilet so this is all new to me, what im wondering is do i need to install anything prior to my tile going down around the toilet drain? or is everything installed after the tile is laid down?
    thank you,
    Brian.
  19. Terry
    Aug 17, 2004
    The toilet is the last thing installed. The floor comes first, then the toilet sets down on the new floor.
    The back mounting blocks will require drilling four holes through the tile. This is because it's a skirted bowl and the mounting is a little different.
  20. mcdonaldb
    May 8, 2010
    Minnesota
    Terry, i should install the closet flange over the tile also, correct? and this can be a regular closet flange from a big box store, i don't need anything specific for the Toto toilets.
Similar Threads: Toto Aquia
Toilet Forum discussions Aquia wall-hung bowl, TOTO tank required? Feb 3, 2017
Toilet Forum discussions Rough in question for TOTO Aquia Oct 26, 2016
Toilet Forum discussions TOTO THU9090R adapter for installing a Washlet on an Aquia Oct 13, 2016
Toilet Forum discussions TOTO Aquia, Shut off Valve blocking Jun 28, 2016
Toilet Forum discussions Does Toto make a unifit adapter for Aquia? Mar 15, 2016
