Toto Aquia Dual Flush - bowl doesn't empty completely
Discussion in 'Toilet Forum discussions' started by hmac, Dec 31, 2005.
  1. hmac
    hmac New Member
    Dec 30, 2005
    Just installed the Toto Aquia Dual Flush toilet. Fixed slow leak from the tank, thanks to the advice found on this forum about sanding the inside of the tank where the bolts go. It seems to be working "effectively" however the toilet bowl does not seem to entirely empty of water upon flushing. The toilet I had before was huge (20 liters?) and I'm just not sure if this is normal for this type of high effiency toilet.
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Big Tank - Little Flush
    The 1.6 gallon toilets have tanks that hold a lot more than 1.6 gallons. I just measured my 5 year old American Standard and it holds 3.7 gallons from about 0.5 inch below the overflow to the lower limit of the drain.
    I installed an Eljer for a neighbor yesterday and the flush valve closes when the tank is about half empty. If you want a bigger flush, you must hold the lever down longer.
    My American Standard came with a little yellow foam float on the flapper chain that kept the float up until the water went down far enough to let the flapper close. I moved the float down as close as possible to the flapper to get more effective flushing.
    The big tank half-empty designs have two effects:
    1. The higher head gets the water out of the flush tank quicker for a more effective flush.
    2. The manufacturers can meet the 1.6 gallon requirement while giving the customers the means to easily get a more effective flush (hence the easily adjustable yellow float).
    I suspect that most 1.6 gallon toilet installations use a lot more than 1.6 gallons per flush from from the time you push the lever to the time the tank and bowl are refilled.
  4. Terry
    Aug 17, 2004
    [​IMG]
    Most tanks nowadays can use sanding on the inside.
    It's the first thing my guys do now.
    There is very little water in the bowl of the Aquia, and yes it does clear.
    It's a washdown, not a siphon bowl, so the old water leaves and the new water comes in.
    It moves 800 grams in the MaP testing which is very good for any toilet.
    I have one in my home, and it's the one everyone wants to use.
    Since you've just installed it, you may want to start using it and see how it works with real stuff in it, not just the water.
    [​IMG]
    I find that there is quite a bit of water washing down the sides of the bowl during the flush.
  5. hmac
    hmac New Member
    Dec 30, 2005
    So far so good
    The Aquia is moving the real stuff well, so to speak. I find it relatively quiet compared to the roar that my older toilet would make when emptying. The refill water appears clear too.
    Thank you for your prompt replies.
Similar Threads: Toto Aquia
Toilet Forum discussions Aquia wall-hung bowl, TOTO tank required? Feb 3, 2017
Toilet Forum discussions Rough in question for TOTO Aquia Oct 26, 2016
Toilet Forum discussions TOTO THU9090R adapter for installing a Washlet on an Aquia Oct 13, 2016
Toilet Forum discussions TOTO Aquia, Shut off Valve blocking Jun 28, 2016
Toilet Forum discussions Does Toto make a unifit adapter for Aquia? Mar 15, 2016
