Toto Aquia and Aquia II
Discussion in 'Toilet Forum discussions' started by schickb, Dec 13, 2008.
  1. schickb
    schickb New Member
    Dec 12, 2008
    Does anyone know the difference between these two toilets:
    CST414M - Toto Aquia Dual Flush Toilet
    CST416M - Toto Aquia II Dual Flush Toilet
    They are both listed on Toto's site and their spec sheets look virtually identical except an 1/8" here or there. They must be different, however, since the 12th Edition MaP test gives the Aquia a 800 perf. number and the Aquia II an 500.
    The Aquia III is an ADA height toilet, and it also gets a 500 perf. number. Thanks for any info.
    Installation instructions for Aquia
    Complete Instructions for the Aquia written by Jamie
  2. schickb
    schickb New Member
    Dec 12, 2008
    Ok I'll partially answer my own question after reading through another Aquia thread:
    http://docs.hdpi.com/PE-Links/Toto/Toto_AquiaComparrisonChart.pdf
    Although that chart shows an Aquia II model with a "universal height" due in Q4 2008 (aka now). So what is the difference between the Universal Height Aquia II and the Aquia III? Just a few stylistic things in the lid and shroud? Man Toto could use some help with their product organization and website.
    Does the integrated trapway in the II and III explain the flushing performance drop? Anyone had practical experience with both? Does the original Aquia really flush solids better?
  4. Terry
    Aug 17, 2004
    The Aquia I has the larger trapway and and open back.
    The II and the III have the enclosed trapway that drops into a flange adapter. The MaP drops a bit, but is still a healthy 500 grams, the performance factor that both John Koeller and I think is suffcient.
    The I and the II have bowl heights of 15-1/8"
    and the III has a bowl height of 16-1/8"
    [​IMG]
  5. toad
    toad New Member
    Mar 5, 2012
    Toronto, Canada
    Aquia or Aquia II?
    Hi,
    I can see that Aquia (model # CT414.01) is now available at closeout price of $127 at Home Perfect, and Aquia II (model CST416M) price is $303.
    Is there a reason not to get the Aquia? Is its performance worse than Aquia II's?
    Thanks a lot.
  6. Terry
    Aug 17, 2004
    Either one would be fine.
    Are you sure you're getting a tank and a bowl?
Similar Threads: Toto Aquia
Toilet Forum discussions Aquia wall-hung bowl, TOTO tank required? Feb 3, 2017
Toilet Forum discussions Rough in question for TOTO Aquia Oct 26, 2016
Toilet Forum discussions TOTO THU9090R adapter for installing a Washlet on an Aquia Oct 13, 2016
Toilet Forum discussions TOTO Aquia, Shut off Valve blocking Jun 28, 2016
Toilet Forum discussions Does Toto make a unifit adapter for Aquia? Mar 15, 2016
