Toto 1,28 Drake versus Toto 1.6 Eco Drake (same price)
Discussion in 'Toilet Forum discussions' started by JLM, Jul 28, 2010.
  1. JLM
    JLM New Member
    Jul 28, 2010
    Florida
    Sorry if this questioned has been asked! I am doing a renovation and replacing 4 toilets (3 on ground level, 1 above garage in new bathroom). I can get the 1.28 Eco Drake or the 1.6 Drake for the same price. I originally liked the idea of less water and saving money (water is not cheap in Florida). I also never thought buying a toilet would be so complicated. Anyway, which is the recommended path? Am I wrong is thinking that the 1.28 Eco Drake can be a 1.6 Drake by just holding the flush handle down a little longer???
    Thanks for any advice/suggestions.
  2. Terry
    Aug 17, 2004
    They weight the flapper down on the 1.28.
    They flush fine with the lower 1.28, but if more water is needed, then holding the handle down a bit longer gives you that.
    In Seattle I still have some CST744E Toto Eco Drakes for $20.00 less until I have to reorder.
    Then they go back to same/same.
    I also have the Drake II CST454CEFG for $35.00 less until I run out and have to reorder.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    The Drake II CST454CEFG is a big time favorite of mine. I consider it to be the best value in the whole Toto line.
    ADA, Sanagloss, and the double cyclone flush for an improved bowl wash how can you go wrong?
  5. jdon88
    jdon88 New Member
    Jul 7, 2010
    Pottstown PA
    I was weighing the same decision a few weeks ago and went for the 1.28. So far no problems, its amazing how little water is used. I've used nothing but pre-94 toilets until now. I haven't given it a 'severe' test yet but 'normal' tests have passed and didn't have to hold the handle down.
  6. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    I've got 2 1.28 Toto Ultramax II's in my house -
    virtually impossible to get them to clog even when you stress-test them.
    Save water, save money, get the 1.28.
  7. JLM
    JLM New Member
    Jul 28, 2010
    Florida
    Thanks for the help. I think I am leaning toward the 1.28. One of the bathrooms is new, it is in a bonus room above the garage. The sewer line is new, it runs across the roof of the garage; down the wall, through the yard where it connects to the main sewer line. This is a question for our plumbing expert, does this configuration make a difference; should I opt for the 1.6 for this one?
  8. jadnashua
    It is a rare sewer line that the waste makes it all the way to the main on one flush. Each succeding flush or water use moves it further. Don't worry about it. If the slope of the pipe is proper, it will work.
  9. SteveW
    Feb 11, 2005
    Omaha, NE
    and in addition, water from sinks, showers, etc. will all give some additional water to help move things down the road.
Similar Threads: Toto Drake
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Tuesday at 3:44 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Feb 18, 2017
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions My Toto Drake, Flush Handle & Flapper Issue Jan 14, 2017
Toilet Forum discussions Toto Eco Drake vs Kohler Wellworth vs AS Champion Pro Jan 1, 2017
