Toro 53709 valve won't close
Discussion in 'Irrigation / Sprinkler Forum' started by donl1150, May 16, 2013.
  1. donl1150
    donl1150 New Member
    Mar 22, 2013
    Akeley, Minnesota
    Trying to get yet the system fired up for the year. Got all zones working except one. Replaced the solenoid and it still won't shut properly. Have not unscrewed to get to the diaphragm but is that the likely cause it won't shut off? Some debris stuck in there perhaps? Other possibilities?
    Thanks
  2. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    Did you replace JUST the solenoid itself, or the whole valve? My limited experience has taught me that these valves have to have thier solenoids screwed into them at the correct depth, or they will not properly seat the pilot (solenoid plunger) seal and this will cause the diaphragm seal to not seat. Using the wrong solenoid, plunger, or incorrect spacer, itf any can do this too.
    Or, the diaphragm may have a crack or dirt like you said in its seat area. Just get a rebuild kit or a new valve assembly to have on hand in case you need anything additional as they are cheap enough. I think the whole assembly costs just a little more than the repair parts
  4. donl1150
    donl1150 New Member
    Mar 22, 2013
    Akeley, Minnesota
    Well, I took the valve body apart, cleaned it up and tried again. Still won't shut off. I did just replace the solenoid only. I then took it apart again and this time discovered a tiny pebble, about 1/16" in diameter. Got that out and now it shuts off except one small 1/4 round fixed spray head is still leaking ever so slightly. The remaining 180 degree heads all shut off.
    I wonder if the diaphragm was damaged by the pebble and just enough water is getting by to open that fixed spray head but not enough pressure to open the bigger heads?
    Are there any good websites to get the repair parts for these valves? The big box stores don't carry repair parts.
    Don
  5. BobL43
    Mar 25, 2011
    Long Island, NY
    Don, Goog;le is your friend; use it: http://www.sprinklerwarehouse.com/Toro-Irrigation-Valves-Replacement-Parts-s/7343.htm.
    http://www.toro.com/sprinklers/valves/inline/53709.html
    I've bought lots of irrigation stuff from them and they are a good vendor, although I am sure their are plenty others out there
Similar Threads: Toro 53709
Irrigation / Sprinkler Forum Toro sprinklerhead not retracting. Apr 18, 2016
Irrigation / Sprinkler Forum Winterizing old hydraulic Toro model 123-01-12. Dec 20, 2012
Irrigation / Sprinkler Forum lost power to Toro Rain Sensor TWRS - help? Aug 28, 2012
Irrigation / Sprinkler Forum Need the black fuse holder and fuse for a older Toro Custom 8, model #123-01-12 Mar 14, 2012
Irrigation / Sprinkler Forum toro Sprinkler system stuck in zone 2 Jul 26, 2011
