too much is going wrong!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by amw04004, Sep 4, 2009.
  1. amw04004
    amw04004 New Member
    Sep 4, 2009
    Arkansas
    Hi, first of all we have a septic system. I don't know if this could possibly be part of the problem or not but I do find it strange that we are having all kinds of plumbing issues that are seemingly unrelated...
    First, we have a double kitchen sink that has always worked fine... now all of a sudden it doesn't want to drain, so thinking it just needs the disposal to be ran, you turn it on and all kinds of nastiness pops up in the other side of the sink.
    Second, our bathtub refuses to drain, no amount of drain-o or snakes or whatever will make it drain.
    Is there anything I can do, or are we just going to have to call a plumber?
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Call the guy that pumps your septic tank.
  4. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Since you have not mentioned any toilet troubles, I would guess you need to clean the trap under the kitchen sink and have someone come clear the drain line for the tub ... and be sure to let him or her know about any and all chemicals you have already tried!
  5. hj
    drains
    Unless your sink has an AAV instead of a vent out the roof, ANY septic problem would not cause your symptoms. IF it were a septic problem the sink WOULD drain, but the water would come up in the bathtub or shower, and your toilet would not flush. You need a plumber to snake the drains and get them flowing properly again.
  6. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    We should start a company pool on these things just for fun.
    I'm still betting on a full septic. I know, the toilet issue, but I done seen this a lot of times. My house in fact. For some strange reason, my toilet will flush and the regular drains won't when the tank's full. Oh, hell, the OP will probably never post what he found anyway. :(
Similar Threads: much going
Plumbing Forum, Professional & DIY Advice How much pressure can 2" DWV pipe take? Is it okay to use in pool plumbing? Jan 8, 2017
Plumbing Forum, Professional & DIY Advice How and how much to tighten this pipe? Sep 5, 2016
Plumbing Forum, Professional & DIY Advice So much water in pressure tank Aug 21, 2016
Plumbing Forum, Professional & DIY Advice PEX bend too much? Aug 8, 2016
Plumbing Forum, Professional & DIY Advice Why do our plumbers suck so much? Jul 8, 2016
