Hey folks.
1st off - been reading for a while and searching for lots of info, so thanks! Newbies always say thanks before throwing out a bunch of questions, huh?
I just started a bathroom remodel and am about to attack the drain lines. It is a small bath with a clawfoot, toilet, then pedestal sink (left to right). The toilet connects to a cast iron sanitary tee and vent. The "toilet tee" sits into a double cast iron tee that the tub and sink (still lead soil pipe) connect into. (All XH cast iron.)
One problem I have is the 1st tee is really high on the soil/vent stack (close to the sub floor). The closet bend attached to about 10" of ABS, through fernco donut into cast iron hub makes it look like a negative slope. Maybe 1/4" max, but still. Are there low profile closet bends? What I have is a simple 90 with hubs on either end. (This set-up was a fix. I drilled out the lead joint as it was leaking about 2 months ago and I knew I was about to demo for the remodel.)
Almost exactly like this post minus the extra purple: https://terrylove.com/forums/showthread.php?t=6751
Now that I am about to replumb everything I thought I need to address my 'uphill plumbing'.
I'll try to post some pictures tonight. I know it will show a lot more than I am able to explain. I'd rather try to keep the cast iron so things will remain nice and quiet.
Thanks in advance!
-Chris-
Thanks in advance!
-Chris-
