Toilets with Clearance for baseboard heat.
Discussion in 'Toilet Forum discussions' started by Arline, May 17, 2007.
  1. Arline
    Arline New Member
    May 17, 2007
    Please, I hope someone can help me. I am a senior gal with some handyman (woman) experience. In the past, I have replaced two toilets on my own. I have now decided that I would like a new lo-flo, REASONABLY priced, Comfort Height toilet. I bought one and when I went to install it, realized that it was configured differently than my older toilets were. The base was much larger. I have a 12" rough, but running along the wall in back of the toilet is the only heat in my very small bathroom. It is a forced hot water baseboard that measures 10" tall X 2-1/4 " deep on the existing wall. I returned my toilet back to the showroom and was told they had no model available that would clear this baseboard, other than the Soiree (too expensive for me). Can this be possible? When purchasing toilets in the past, the baseboard was never a consideration. Before, I just went to the store, bought a toilet and dropped it in. Now I am told, this is no longer possible, in a comfort height model.
    Does anyone know of a good working toilet that will solve my problem? Also, what is the exact measurement for ADA compliance? I have looked at higher toilets ranging from 15" to 17-1/2 " I did find the 17-1/2" to be the most comfortable. This was a St. Thomas but I could find no reviews on it.
    Any info you could provide would be most appreciated.
    Thank you in advance,
    Arline
  2. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    Toto has two heights for comfort.
    16 1/8" which is any toilet ending with "F" ie: C734F Dalton or
    16 1/2" which is any toilet ending with "L" ie: C744SL Drake (also referred to as ADA). Also add the hieght of the toilet seat.
    Toto's specs do not say anything about the space behind the toilet.
    I can check the toilets in my showroom on Tuesday (Monday being a holiday in Canada) to see if any comfort height will fit.
    If any one else can do it quicker for you that would be good.
    [​IMG]
    Toto Dalton with room behind the bowl.
  4. Arline
    Arline New Member
    May 17, 2007
    Thank you. I was in a Toto showroom and none of theirs would fit. However, they did not have all the models there. Any help you could give would be appreciated. Toto is my first choice.
    Arline
  5. Peanut9199
    Apr 23, 2007
    Ontario, Canada
    Ok i checked my showroom and found three that has that clearance.
    1- Promenade C724 (Elongated) or C723 (Regular Rim) this is an older style looking toilet but it's not available in "Comfort Height".
    2- Carusoe C716 (Elongated) or C715 (Regular Rim) this is a standard looking toilet, looks like a Drake but without the G-Max flush. Also not available in "Comfort Height".
    3- Reliance C704L (Elongated) or C703 (Regular Rim) this is classed under thier commercial line, but flushes same as Carusoue. The C704L is and only comes as ADA and the C703 is only availble in regular height.
    Now you can use the C704L (Reliance) bowl and the ST706 (Carusoe) tank together and the ST706 tank is also avaiable with a liner ST706D.
    Hope that helps
  6. Arline
    Arline New Member
    May 17, 2007
    Hi again,
    Thank you for all of your imput. I didn't even know that ToTo had a commercial line. I would have prefered the G-Max system, but will keep your recommendations in mind as I search a little longer. Thank you again.
Similar Threads: Toilets Clearance
Toilet Forum discussions Older toilets are gold! Jan 13, 2017
Toilet Forum discussions Wall mount toilets- fastening systems Jan 9, 2017
Toilet Forum discussions How toilets work - holding the handle down for more water Nov 14, 2016
Toilet Forum discussions Products to clean Toto toilets Sep 3, 2016
Toilet Forum discussions Re-route of back-to-back toilets to new sewer hook-up Sep 1, 2016
