I had my bathroom tile redone and now my toilet will not flush with any type of seal between the floor flange and the bottom of the toilet. The only way the toilet will flush is if I install it without any wax etc. I get the impression that air is being made by toilet and filling up the waist pipe causing the toilet not to flush if sealed.
When the toilet was reset after the tile work was done the water went down very slow. I taught the wax ring may have blocked the waste pipe. The toilet was pulled up and there was no signs of any wax where it shouldn't be.
I put a new wax ring down smashed it enough so t did not stick to the toilet. When I did this the toilet flushed fine. Ive tried the fluidmaster waxless gasket. The result was the same as with the wax ring. No flush. My other toilet in my second bathroom back 2 back with the problem toilet works fine. no problem. Does anyone know what would cause a problem like this? All my Vents have been cleaned out etc. no blockage anywhere. Attached are photos of the floor flange. This toilet is an old American Standard Plebe from 1974, Ive even replaced the toilet and still same story. I know its not the toilet due to the old and new one doing the same thing. Anyways just taught Id check here first before being forced to fork up the cash to have my problem professionally fixed.
