toilet water supply turnoff too close to floor
Discussion in 'Toilet Forum discussions' started by newbrain, Mar 29, 2012.
  1. newbrain
    newbrain New Member
    Sep 25, 2011
    MA
    We are tiling the bathroom and after setting backer board, thinset and tile, we're raising the floor almost an inch.We won't be able to turn off the water because the knob will probably be right at floor level. We'd like to avoid having to solder an extension but... Are there any options. Thanks.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You should explore the 1/4 turn valves. These do not have to be twisted around and around. A toilet supply valve should always be fully on or fully off, so there is absolutely no advantage to the older type valves. You might also want to consider opening the wall and raising the pipe several inches. Yes, it very well could mean having to sweat a joint or two, but unless you are totally inept, this is a relatively quick and simple job. I'd still recommend the 1/4 turn valve.
    [​IMG]
    Standard handle and 1/4 turn handle
    Dahl valves
    [​IMG]
  4. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    How would a 1/4 turn valve help?
  5. Hackney plumbing
    Jan 6, 2010
    Alabama
    If you cant or do not want to raise the pipe and its coming out of the wall you could buy a straight stop. This way the handle would be on top not on the end.
    If the pipe is coming out of the floor you could use an angle valve. This would put the handle on top also...away from the floor.
    How is your current valve attached to the pipe? Solder?
  6. jadnashua
    You might find a round knob might have clearance where an oval one didn't. Then, while not as handy, they do sell the valves with a removeable key rather than a knob. You could probably get a couple of positions where the key could be engaged to avoid it hitting the floor. But, if this is either in the wall or coming out of the floor, the better choice would be to replace the valve. If it's coming out of the floor, BrassCraft sells a chrome plated 5" valve that slides over the copper stub, putting the valve up in the air. If it's coming out of the wall, they sell right-angle valves that would raise it away from the floor. Dahl makes a nice one, and probably others. It depends on how the existing one is attached what your options are. If it is threaded on, you may not have enough room to unthread it. If it is either soldered or a compression, you should be able to get the old one off and a new one installed fairly easily.
  7. hj
    A 1/4 turn valve usually has a lever rather than an oval handle, and it only turns 90 degrees so if it is above the floor, the handle does NOT have to rotate to hit the floor.
Similar Threads: toilet water
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Today at 9:53 AM
Toilet Forum discussions Toilet Water Gets Gone Feb 1, 2017
Toilet Forum discussions Better Toilet for Hard Water/Iron Conditions? Jan 30, 2017
Toilet Forum discussions Toilet water supply has been off a while...try to turn back on now and get a horrible loud noise... Jan 18, 2017
Toilet Forum discussions Toilet bowl slowly leaks water Dec 15, 2016
