toilet w/ sump or ejector pump
Discussion in 'Toilet Forum discussions' started by kmspca, Jun 21, 2006.
  1. kmspca
    kmspca New Member
    Jun 21, 2006
    i'm putting a toilet in my basement that is below the sewer line. i know that i will need either a sump pump or ejector pump. does anyone have a recommendation? also, does it matter which toilet i use with the pump? i'm thinking of one of toto's w/ g-max flushing & wonder if this will work.
    thanks for the advice.
  2. prashster
    prashster New Member
    Dec 7, 2005
    If yr gonna do an inground pump, you want a sewage pump. A sump pump is for ground water only. Sewage pumps have a macerating blade that chops up da nasties. Around this forum, Zoeller gets consistent high marks. IMHO stay away from the big box brands. It's WELL worth the extra $50 to get a better pump. I speak from experience.
    These pumps are designed to sit in the ground in a concealed pit. The pit is designed to accept drain lines like the rest of yr house, so ANY toilet will work with this. Know, though, that the hard work is digging thru the concrete to seat the pit and the drain lines.
    If that work has not been done yet, then you'll do well to CONSIDER an above-ground pump unit (also made by Zoeller) or Saniflo that sits behind yr toilet. You have to use a special toilet for that type of unit. Also, the inlet and discharge are smaller than the inground units so they are reputedly prone to clogging. But, for their ease of installation, it's definitely worth a look see.
Similar Threads: toilet sump
Toilet Forum discussions How is the toilet made the difference between 1.28 and 1.60 GPF toilet? Saturday at 9:18 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
Toilet Forum discussions Toilet leaks than stops Thursday at 9:59 AM
Toilet Forum discussions Baffled! Replacing existing same toilet does not fit!! Wednesday at 8:51 AM
Toilet Forum discussions Is there any Toto 1.6 gpf double cyclone toilet with ADA compliant in the market? Tuesday at 9:11 PM
