Toilet venting under the Illinois Code
Discussion in 'Illinois Plumbing Code Questions' started by Neptune, Oct 31, 2012.
  1. Neptune
    Neptune New Member
    Oct 31, 2012
    Illinois
    I'm interested in relocating a toilet to the other side of a second floor bathroom. This would entail a 3" drain with a developed length of about 8 feet back to the existing soil stack/vent. There would be no easy option to install an additional vent in the toilet drain anywhere near the closet bend. A new shower drain (with its own separate vent) would connect into the toilet drain several feet downstream from the toilet.
    Local code incorporates both the IRC (2006) and the Illinois Plumbing Code.
    The IRC seem to allow any length for an "unvented" toilet drain, if at the stack there is a sufficient vent.
    The Illinois Code (sections 890.1470 and .1490) seem to require a vent within 6 feet of the toilet.
    Do I need to figure out a way to add a vent to the toilet drain line in order to comply with Code? If not, would adding such a vent improve (or possibly degrade) the performance of the toilet in terms of the strength of the flush or the risk of blockage building up over time?
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    You must follow the Illinois code as it is the minimum standard set by the State. You can always be more strict, or go above and beyond the code but nothing less.
Similar Threads: Toilet venting
Illinois Plumbing Code Questions Master Bath - Wet Vent Toilet & Fixture Horizontal to Trap Jan 3, 2016
Illinois Plumbing Code Questions Washing Machine/Toilet setup? Illinois Plumbing Code Jul 2, 2010
Illinois Plumbing Code Questions Horizontal wet venting questions. Dec 4, 2016
Illinois Plumbing Code Questions Code relating to venting Air Admittance Valves (AAVs) for remodeling May 14, 2014
Illinois Plumbing Code Questions Question on venting?? Feb 19, 2013
