toilet too close to tub
Discussion in 'Toilet Forum discussions' started by lesley, Sep 18, 2005.
  1. lesley
    lesley New Member
    Sep 18, 2005
    I just moved into a new rental apartment. The previous owner put in a very wide tub, and now there's not enough room between the front of the toilet and the tub. I think my landlord may be amenable to solving the problem, provided the solution isn't too expensive. The current toilet is a Universal Rundle (12-inch rough-in) which looks to be about 29 inches from back to front, plus there's a gap between toilet and wall because we've got a 14-inch rough-in. I think what I need to find is a very small toilet under $250, with either a 14-inch rough-in or 12-inch rough-in (I can live with the gap). Any suggestions? Please don't suggest the Toto with the adjustable rough-in, as I don't believe my landlord will spring for a $500 toilet.
    Thanks.
  2. AMills
    AMills New Member
    Sep 17, 2005
    The Toto may still be the way to go
    lesley, the landlord may not think that a $500 toilet is too expensive (it depends on your perspective). If you live there long enough, your rent will pay him back for the expense and it's tax deductible for him. If that toilet solves the problem, then he won't have to listen to the next tenant(s) complain about it. Sorry I couldn't come up with a better toilet idea for you.
    Good luck.
  4. jimbo
    jimbo Plumber
    What clearance do you have from the toilet to the tub? There are some minor differences between models. You can check specs on all the websites. If you have an elongated bowl, you could gain about 3 inches by switching to a round.
Similar Threads: toilet close
Toilet Forum discussions Toto Toilet Flapper closes too quickly Feb 6, 2017
Toilet Forum discussions When toilet's clogged, flapper won't close Aug 9, 2016
Toilet Forum discussions Cutting toilet closet bolts Apr 8, 2016
Toilet Forum discussions Toilet flange - cast iron and broken lead closet flange Nov 8, 2015
Toilet Forum discussions Bemis Whisper Close StaTite toilet seat doesn't cover bowl Jun 7, 2015
