toilet to shower drain conversion
Discussion in 'Shower & Bathtub Forum & Blog' started by bscandanavia, Jun 20, 2005.
  1. bscandanavia
    bscandanavia New Member
    Jun 20, 2005
    Hello,
    My wife and I are doing some work to convert a commercial loft into a liveable artist space in NYC. There are two bathrooms with commercial toilets, one of which we would like to convert to a shower.
    The floors are concrete slab and if at all possible we want to avoid jack-hammering into it as the space is a rental and there is a limit to the amount of work we are able to put into it.
    We are hoping that we can build a raised platform to build a p-trap above the concrete floor and feed that out through the toilet drain. Is it possible to convert the toilet waste drain into a shower drain?
    Also, the space is pretty old and there is a possibility that the toilet drain is lead pipe (we still need to remove the old toilet to see). If that is the case - will we be able to connect PVC/copper/brass pipe to the lead pipe? Can we somehow connect to the toilet drain flange?
    Any advice is greatly apreciated.
    best,
    David
  2. jimbo
    jimbo Plumber
    A raised floor is most cases in an ugly idea, but I can see in a loft it may well be doable. A good plumber can make the approriate connection to a lead closet bend. The problem might be avoiding an "S-trap" configuration, but the plumber could help figure this out.
  4. hj
    shower
    IF it is a lead bend and it appears that NYC still uses them to this day, then there is little hope of making a connection to it. Raising the floor and putting the "P" trap above the floor will create an "S" trap and it will require some creativity on the part of a good plumber to avoid the problems with that.
Similar Threads: toilet shower
Shower & Bathtub Forum & Blog Advices needed : Toilet and shower drain Nov 20, 2015
Shower & Bathtub Forum & Blog Leak under shower/toilet slab area Mar 15, 2015
Shower & Bathtub Forum & Blog mini shower/toilet waterproof Mar 6, 2013
Shower & Bathtub Forum & Blog Cracked Cast Iron Stack or junction between toilet and shower Sep 20, 2011
Shower & Bathtub Forum & Blog Help: Hear toilet flushing and smell poo through shower. Aug 10, 2010
