Toilet to fit under 30 inch banjo countertop..
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by JeffH, Aug 7, 2011.
  1. JeffH
    JeffH New Member
    May 21, 2006
    California
    Hey folks,
    Is the Toto supreme my only choice here?
    1) Must fit under 30 inch banjo countertop.
    2) ADA height seat.
    3) Like to stay away from Kohler "lowboy" type toilets if possible :)
    Thanks in advance!
    [​IMG]
    Supreme II, ADA
    Top of tank is 25-9/16"
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You should check out the Toto Ultramax ADA. It is 29-1/4" high. Another choice would be the Toto Supreme ADA. It is only 25-1/2" high. Both of these measure 16-1/2" from the floor to the top of the bowl.
  4. Terry
    Aug 17, 2004
    Supreme II, MS634164CEFG, 26" to top of tank
    Supreme ADA MS864114L, 25.5" to top of tank
  5. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    Go with the supreme or remove the banjo. Its nice having room if you need to change out parts in a few years.
  6. jimbo
    jimbo Plumber
    San Diego, CA
    Banjo countertops were a bad idea from the git-go. But if you must stay with it, your toilet choices are limited, and if you want ADA bowl, I think that rules out any two piece toilets. That would require a total tank height including the lid and the tank to bowl gasket space, of under 13" .
  7. JeffH
    JeffH New Member
    May 21, 2006
    California
    Much Thank!
    I figured that the Supreme would be my best bet. Thanks for the input.
  8. hj
    quote; if you want ADA bowl, I think that rules out any two piece toilets.
    Interesting comment, since the ONLY ADA toilets I have seen WERE two piece ones.
  9. Terry
    Aug 17, 2004
    hj,
    That may be true for you and your customers, but I sell and install lot's of one-piece ADA toilets.
    Most of my one-piece toilets that I sell meet the ADA requirements.
    Most of the older people are the ones with more money and they don't need to skimp on themselves.
  10. hj
    I don't have "cheap" customers, but I cannot remember EVER installing a one piece ADA toilet.
  11. Terry
    Aug 17, 2004
    Too bad.
    I install them all the time. A real popular one is the TOTO Ultramax II. 28-3/4" to top of tank and it's ADA.
    For working on the insides, you gain 2" with the tank lid off.
    [​IMG]
    This won't fit under a banjo top, but it's pretty nice.
    MS604114CEFG
    [​IMG]
    This one is also ADA, with the top of the lid coming in at 28"
  12. taker
    taker New Member
    May 15, 2014
    new jersey
    Toilet for Banjo top
    Hi Can someone suggest a good toilet either 16-17 " from floor to seat that when the seat is in the up position it fits under 34" banjo top and you can still get into tank for repairs? Thanks
  13. hj
    There are almost NO modern toilets that fit under banjo tops and still have room for repairs, unless they are one piece.
  14. Terry
    Aug 17, 2004
  15. taker
    taker New Member
    May 15, 2014
    new jersey
    The counter is 34" and I need to make sure the seat can open and not hit the banjo, Thanks
  16. Terry
    Aug 17, 2004
    How deep is the banjo top from the wall?
  17. Sluggo
    Sluggo Member
    Mar 28, 2014
    Washington
    Whatever toilet you install should have enough clearance that you can replace the flush valve when you need to. Having something that clears the underside of the countertop by a couple of inches would mean pulling the toilet or at least removing the tank if you have to do any maintenance.
  18. hj
    he original poster JeffH said his was 30" and 4 1/2" is not a lot of room to get your hands down to the bottom to replace a flapper.
  19. taker
    taker New Member
    May 15, 2014
    new jersey
    I havent ordered it yet . the one I am replacing is 9" deep
Similar Threads: Toilet under
Plumbing Forum, Professional & DIY Advice Easy way to judge state of floor under toilet? Jul 6, 2016
Plumbing Forum, Professional & DIY Advice Water coming under base of toilet, sewer gas smell laundry room? Feb 6, 2016
Plumbing Forum, Professional & DIY Advice Toilet leaking under lock in place tile Oct 26, 2015
Plumbing Forum, Professional & DIY Advice Toilet Under the Rim needs a good clean and I need a good stopper Oct 3, 2015
Plumbing Forum, Professional & DIY Advice Drain Flies Under toilet Jul 27, 2015
