toilet tank
Discussion in 'Toilet Forum discussions' started by farrington, Apr 24, 2006.
  1. farrington
    farrington New Member
    Nov 9, 2005
    I did my first toilet install over the weekend and so far so good. One thing I'm not so sure about is the tank. I was told tighten the tank up until it touches the two ridges on the bowl that keep it from rocking front to back. I tightened up the bolts but the tank is still around a 1/16 to an 1/8 away from the ridges. They are pretty tight. I don't want to go any tighter fearing I might break something. The rubber gasket between the tank and the bowl is the correct one so there isn't an issue of it being too thick for the toilet. Is it normal for this to happen sometimes?? I was thinking a couple plastic shims should take care of it. thanks
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    It's ok. Your looking for problems if you go china to china. A little wobble is good. If you really have to shim, use a little sheet rubber at the back side will do.........
Similar Threads: toilet tank
Toilet Forum discussions Is it correct 1.28 GPF is not determined by the toilet bowl but tank? Tuesday at 3:32 PM
Toilet Forum discussions Need Norris Toilet Tank Repair or replacement Feb 11, 2017
Toilet Forum discussions Alternate Tank Lid for Toto Drake 1.6gpm Toilet Dec 31, 2016
Toilet Forum discussions I have a Kohler wall mount toilet with a Geberit wall mount tank/ carrier Dec 13, 2016
Toilet Forum discussions four bolt toilet tank Dec 13, 2016
