Toilet Tank Water Won't hold
Discussion in 'Toilet Forum discussions' started by jerome8283, Dec 30, 2008.
  1. jerome8283
    jerome8283 New Member
    Oct 4, 2006
    New York
    My toilet often runs as if it were just flushed. Also I can hear water trickling. The floor is dry. Today I did a test by flushing the toilet, letting the tank fill and shutting off the water supply line to see if the water in the tank would maintain its level. I checked it less than 2hrs later and the water was almost completely drained. What do you think the problem is?
  2. Probedude
    Probedude New Member
    Nov 25, 2008
    CA
    What shape is the flapper in the tank? It's likely just that it needs to be replaced.
  4. jerome8283
    Oct 4, 2006
    New York
    The toilet is fairly new, a few months old. Would the flapper need replacing so soon?
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It sure sounds like a flapper problem. It is awfully soon for the flapper to be bad, more likely it's not seating properly.
  6. jerome8283
    Oct 4, 2006
    New York
    Thanks guys. I will take a look.
  7. Donn2390
    Donn2390 Member
    Dec 12, 2008
    Riverside, California
    If you put some of that junk in the tank they sell under the pretense of keeping the bowl clean, most of those chemicals will destroy the rubber parts in a hurry...
  8. theplumber
    theplumber Member
    Dec 20, 2008
    CA
    Also check the handle and makes sure it's not holding up the flapper just above the sealing point. Another thing to check is the chain itself and how it rests. If you have too much slack, it can get under the flapper and keep it from sealing. You want just a little bit of slack when in the closed sealed position, no slack and you can run into a sticky handle holding the flapper up too high to seal.
Similar Threads: Toilet Tank
Toilet Forum discussions Is it correct 1.28 GPF is not determined by the toilet bowl but tank? Tuesday at 3:32 PM
Toilet Forum discussions Need Norris Toilet Tank Repair or replacement Feb 11, 2017
Toilet Forum discussions Alternate Tank Lid for Toto Drake 1.6gpm Toilet Dec 31, 2016
Toilet Forum discussions I have a Kohler wall mount toilet with a Geberit wall mount tank/ carrier Dec 13, 2016
Toilet Forum discussions four bolt toilet tank Dec 13, 2016
