Toilet tank has no bolts ?
Discussion in 'Toilet Forum discussions' started by cdm, Jun 10, 2006.
  1. cdm
    cdm New Member
    Jun 10, 2006
    So , my toilet tank has no bolts. This is an old toilet and the gasket between the bottom of the toilet tank and where it rests on top of the back portion of the toilet bowl is leaking. I guess it's one of those tanks where you screw the whole tank directly on top of the back of the toilet because there is no tank bolts. So the question is: I tried to remove as much of the disintegrating gasket as I could and then I applied as much silicone sealant as I could to seal it up since it's up against the wall and bolted to the cement floor. It's probably not up to code but is this adequate ?
    Thanks
    Chris
  2. jadnashua
    If it doesn't leak...go for it. My unprofessional opinion. Depending on how much this bathroom is used, and your costs for water and sewer, a new one might be a good idea sometime in the future, but there is something to be said for maintaining the status quo, too. Taking apart the (probable) nut and threads on something that old is likely to lead to something that you might not be able to get parts for, then you'd have no choice but to replace.
Similar Threads: Toilet tank
Toilet Forum discussions Is it correct 1.28 GPF is not determined by the toilet bowl but tank? Feb 14, 2017
Toilet Forum discussions Need Norris Toilet Tank Repair or replacement Feb 11, 2017
Toilet Forum discussions Alternate Tank Lid for Toto Drake 1.6gpm Toilet Dec 31, 2016
Toilet Forum discussions I have a Kohler wall mount toilet with a Geberit wall mount tank/ carrier Dec 13, 2016
Toilet Forum discussions four bolt toilet tank Dec 13, 2016
