toilet tank condesation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Master Brian, Dec 27, 2008.
  1. Master Brian
    Master Brian DIY Senior Member
    Nov 13, 2008
    Kansas
    What might cause this?? Last night we had about 3 couples and their kids over. At the end of the night, I noticed the tank on the newly installed toilet had a bunch of condesation on it and it was dripping all over.
    The only thing I can think of is that it has been really cold the last few weeks, temps in the single digits. Then yesterday we set a record high of high 60's for the day.
    The only thing I can figure out is that because of the really cold weather, the water in the ground is colder than normal and then with the house being warmer than usual with unusual warm temp and a houseful of people, probably using the toilet a bunch. I'm thinking on a normal day, the water set in the pipes long enough to warm up a bit, but with all the people the water kept getting refreshed and the coldest water outside was coming in causing the problem.
    Is there anything else that might be at play??? The toilet has been installed for about a week and never noticed this and today, the problem isn't there.
    Main lines coming in are copper, then I have pex feeding the toilet.
    Thanks for any response....
  2. Terry
    Aug 17, 2004
    With that many people using the toilet, it kept the tank cold with incoming water.
    The same thing will happen if the tank has a leak. The cold water is like a glass with ice cubes in Summer. The outside sweats.
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    The fill valve may not be sticking.
  5. Master Brian
    Nov 13, 2008
    Kansas
    So my thoughts are correct, I'm supprised this has never happened before. There might be a small leak on a supply line as well, I just haven't had a chance to correct it.
    Thanks for the reply.
  6. Master Brian
    Nov 13, 2008
    Kansas
    Like I said a supply line does have a drip, which should be fixed later today, if I get motivated, I don't think anything inside the toilet is leaking, but I'll check that out as well. Like I said it hasn't happened until last night.
    Thanks for the replies!!
Similar Threads: toilet tank
Plumbing Forum, Professional & DIY Advice Toilet Lid Bangs Into Tank! Sep 30, 2016
Plumbing Forum, Professional & DIY Advice My toilet lid fell inside the tank and caused a hissing noise.... Oct 25, 2015
Plumbing Forum, Professional & DIY Advice Help! Toilet losing water (internal), wakes me up at night because it refills tank Jul 5, 2015
Plumbing Forum, Professional & DIY Advice Toilet tank drains into bowl May 4, 2015
Plumbing Forum, Professional & DIY Advice Narrow tank toilets? Dec 4, 2014
