toilet supply makeover options...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by roadk, Nov 26, 2009.
  1. roadk
    roadk New Member
    Jul 22, 2006
    New York
    here's a photo of my toilet supply line.
    i would like to dress it up and was looking for suggestions to get some chrome on it to match the rest of my bathroom hardware.
    i can't (or would rather not) remove any of the beadboard.
    any suggestions would be great appreciated.
    -thomas
  2. Terry
    Aug 17, 2004
    I can't see the picture, but a new chrome shutoff and escutcheon will look nice.
    When we do our toilet replacements, we charge $50.00 while we are there to replace the shutoff.
    If its a copper pipe from the wall, a sleeve puller will remove the back nut.
    If it's an old galvanized pipe, then you can remove that, and use a brass nipple, or a chrome plated brass nipple.
    [​IMG]
  4. roadk
    roadk New Member
    Jul 22, 2006
    New York
  5. Terry
    Aug 17, 2004
    Measure how much shorter you want the new nipple,
    Pull out the old one, and subtract them amount you will be removing.
    If you want if three inches closer, get a nipple that is 3" shorter.
    Then get either a chrome plated nipple, or if it's tight to the wall like the picture above, you can use a brass nipple.
    That is way too far out from the wall.
    You will be getting a new supply tube anyway.
    Now that I see the picture, just cut the copper shorter, use an escutcheon and a compression shutoff.
    But keep it close to the wall.
  6. roadk
    roadk New Member
    Jul 22, 2006
    New York
    thanks terry. i appreciate the help.
    have a great thanksgiving!
    -thomas
  7. Mike Lopez
    Mike Lopez Plumbing Inspector
    Nov 26, 2009
    Plumbing Inspector
    Niagara Falls
    TEST test test
  8. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    The link that you have is exactly what you want, you don't need a coupling, the chrome tube slides over the copper stub, don't forget to put the bell flange on before you solder it, luck :)
  9. hj
    supply
    Do it the way we do with EVERY installation. Cut the tubing 1 1/2" from the wall. Slide on a spun escutcheon, then a compression valve and tighten it. Finally get a "good" supply line and install it between the valve and the toilet.
  10. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    If you leave the copper that long this is what happens.
Similar Threads: toilet supply
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Today at 8:27 AM
Plumbing Forum, Professional & DIY Advice Water supply line to short for new toilet Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Can I use the cold water supply to supply toilet Mar 20, 2016
Plumbing Forum, Professional & DIY Advice Constraints of skirted TOTO toilet - wrt to water supply outlet? Jun 17, 2015
Plumbing Forum, Professional & DIY Advice Tubs, Toilets, Faucets at Plumbing Supply Versus Big Box Stores Feb 28, 2014
