Toilet size
Discussion in 'Toilet Forum discussions' started by Emilia, Mar 13, 2010.
  1. Emilia
    Emilia New Member
    Mar 13, 2010
    Hawaii
    I live in an older home in Hawaii that is single wall construction. The concrete foundation of the house extends into the bathroom by 4" wide and 7" high. Our 1952 toilet needs to be replaced and I can't find a toilet that will fit because the design of new toilet bowls extend too far to the rear and there is no clearance between the back of the toilet bowl and the foundation. We need a toilet with a clearance of 7 3/4" at the rear with a 12" rough-in. We spoke to a Toto technician and he jokingly said we probably could use a toilet with an 8" rough-in, which doesn't exist as far as we know. We are interested in Toto toilets but at this point, we will consider any toilet that will fit the space and has a good performance record. Our plumber has looked at our situation and agrees that we have a problem. Any recommendations or suggestions will be greatly appreciated.
  2. hj
    We can't correlate the 7 3/4" at the rear and 12" rough. Are you saying that there is only about 8" behind the pipe, even though the pipe is 12" from the wall if you measure higher?
  4. Emilia
    Emilia New Member
    Mar 13, 2010
    Hawaii
    That's correct. There is only about 8" from the pipe to the foundation that extends in behind the toilet.
  5. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Is that from the center of the pipe or from the end of the flange?
    John
  6. Emilia
    Emilia New Member
    Mar 13, 2010
    Hawaii
    It is from the center of the pipe.
  7. Emilia
    Emilia New Member
    Mar 13, 2010
    Hawaii
    I want to thank those who answered my post. Your questions have helped me to understand what measurements I need to ask for when l contact the different toilet manufacturers or dealers. It is so difficult to explain my situation. I have looked at toilets on several websites and checked specifications but most do not give the measurement I need. The ones that do, the distance is not enough. I'm hoping there is a toilet out there that will give me the clearance I need.
Similar Threads: Toilet size
Toilet Forum discussions Toilet size, etc. issues. May 11, 2013
Toilet Forum discussions Loose tank - wrong size toilet? AquaSource toilet 1.28 Dec 23, 2012
Toilet Forum discussions What size toilet should I shop for 11 - 11.5"? Also flange anchoring question Dec 6, 2011
Toilet Forum discussions A simple question: are the water lines that go to the toilet tank all the same size? Jul 13, 2011
Toilet Forum discussions Will toilet trap size help with this? Oct 12, 2010
