Toilet Shower Sink drain venting, Canada
Discussion in 'Canadian Plumbing Code Questions' started by dodge1930, Jun 29, 2010.
  1. dodge1930
    dodge1930 New Member
    Jun 29, 2010
    Montreal. QC
    I am relocating my bathroom and the new setup will have: from basement 3" waste stack running up to basement ceiling then horizontal 18' to the front of the house into wye 3x3x2 to pick up shower then 4' into wye 3x3x3 to pick up toilet then into wye 3x3x2 to pick up sink then 3" to 2" to vent up the wall to roof.
    4' between shower and toilet.
    sink 3-4' from 3"
    3" runs directly under shower and toilet bewtween floor joist.
    Is it ok to vent this way?
  2. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Nope you can't do that because you have a fly dry vent AND you are wet venting a fixture past a water closet. You can't do this either.
    You need to tie the sink drain into the vertical "2 vent" you have labelled. Then you also need to try and tie the shower drain in upstream of the toilets trap arm. And if you can't do this then you would technically need to seperately vent the shower without a flat dry vent.
Similar Threads: Toilet Shower
Canadian Plumbing Code Questions Composting Toilets Jun 3, 2016
Canadian Plumbing Code Questions short radius 90 degree elbow under toilet Mar 12, 2013
Canadian Plumbing Code Questions Wall mount toilet. Mar 11, 2013
Canadian Plumbing Code Questions Venting Possibilities for basement toilet Jan 2, 2013
Canadian Plumbing Code Questions When is a toilet vent not required? Feb 27, 2012
