Gsensel
I am going to do a full remodel of my bathroom. Practically gut it or gut it (only thing I'm undecided on is the tub). Currently there is a 12 inch toilet installed on a 14 inch rough in. This is contributing to the reason I am need to do work. The toilet has rocked causing it to work lose of the wax ring and is causing the sub floor to weaken making the toilet rock and making the above issues worse. In my remodel I am going to redo the whole sub floor and put in a new toilet. I have asked on another forum and was told it was likely not installed properly to begin with. Based on what I am seeing and learning I agree but this was 1-2 owners ago, so not much I could do as it seemed in good shape 1.5 years ago.
I have seen several people talk about using an off set, but I have also seen people say don't because they do not work and mess up the modern low flow toilets. Others have said they might be against building codes.
This is the general direction I am going for a replacement toilet. Mansfield I like the dual flush because currently I practice yee old "If its yellow let it mellow, if its brown flush it down" I am a single male so I can get away with it, but I hope in the future that will change. I have also been looking at the Aquia line because it is dual flush as well will it work with the unifit system or are there and dual flushes offered that will?
Also if I can't find a 14 or unifit that fits my wants could I install the 12 inch and then add some sort of support behind it to keep it from having the extra 2 inches of space to prevent it from being able to rock which started this whole issue to begin with.
