Toilet Question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DeeJay77, Aug 1, 2013.
  1. DeeJay77
    DeeJay77 New Member
    Aug 1, 2013
    United States
    I replaced the flush fill valve, flapper, and flush handle. I dumped a bucket of water into bowl while flushing to see if the toilet trap and/or drain line beyond the toilet was semi-clogged. The toilet flushed immediately with help of the bucket of water, eliminating the possibility of a trap/drain clog. Then I also cleaned out the holes under the bowl rim with metal clothes hanger to no avail; toilet still barely flushes and swirls very slowly. Any suggestions?
  2. jadnashua
    It is critical that both the bowl AND the tank get properly filled during a flush/refill cycle. If the bowl starts out less than full, it will not flush well. Flush the toilet, note where the water level is in both the tank and bowl after it's refilled. THen, take your bucket and slowly pour water into the bowl. If you can get the water higher in the bowl (it will take a few moments after pouring to stabilize), then the bowl is not being filled, and the flush can be poor. There are some aftermarket filler valves that are adjustable to get the balance right...you may need one of those.
    THen, if your toilet has a siphon jet (a hole down near the bottom of the bowl), this may be clogged. If it has one, this creates a jet of water to start the water leaving the bowl. If that is plugged up, it won't flush well. On some toilets, they used a float on the flapper valve...plumbers have reported finding several of those clogged inside the internal passageways. If your toilet design uses one of those, and you seem to have lost one, that may be your problem.
  4. MichaelBukay
    MichaelBukay Plumber
    Jan 14, 2013
    CA Plumbing Contractor, Working for the man in CO
    Conifer, Colorado
    did you replace the flush valve and the fill valve, or just the fill valve or flush valve? what make is the toilet and how old is it?
Similar Threads: Toilet Question
Plumbing Forum, Professional & DIY Advice Toilet Flange Install Question Dec 29, 2016
Plumbing Forum, Professional & DIY Advice Toilet flange question Dec 20, 2016
Plumbing Forum, Professional & DIY Advice Stone (often marble) toilet slab questions Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Question about wet venting a toilet and shower Nov 15, 2016
Plumbing Forum, Professional & DIY Advice Back to Back Tub and Toilet DWV Question Oct 18, 2016
