Toilet? Pressure Problems
Discussion in 'Toilet Forum discussions' started by sjp5028, Dec 15, 2004.
  1. sjp5028
    sjp5028 New Member
    Dec 15, 2004
    I have three toilets in my home
    All are new
    One was installed 14 months ago (lower level)
    Two were installed 10 months ago (upper Level)
    Recently all the toilets keep "running" after the tank fills.
    If I open the faucet at the sink the "running" stops immediately.
    Any help?
  2. ocpilot
    ocpilot New Member
    Dec 13, 2004
    You might consider disassembling the fill assembly in the toilet and check for dirt, sand etc.
    I had a similar situation after doing some outside repairs on my main. Got a bunch of sandy dirt in the line. Caused every toilet in the house to run until I dismantled and cleaned.
  4. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    Adjust Water Level
    You probably just need to adjust the water level in the tanks. It should be below the overlow tube opening about an inch. As the toilets get used the washer in the fill valve gets an indentation that allow the water level to rise.
Similar Threads: Toilet Pressure
Toilet Forum discussions Putting a pressure assist in an older toilet. Tuesday at 5:36 PM
Toilet Forum discussions Pressure assisted toilet sprays seat Sunday at 7:30 PM
Toilet Forum discussions Pressure assited toilets: best supply pressure and outflow pipe joint stress Aug 27, 2015
Toilet Forum discussions Need toilet that (hopefully) won't clog, looking for pressure assist Apr 3, 2013
Toilet Forum discussions Pressure flush toilet leaks at floor Sep 13, 2012
