Toilet plumbing installation
Discussion in 'Toilet Forum discussions' started by SteveMN, Mar 9, 2009.
  1. SteveMN
    SteveMN New Member
    Mar 9, 2009
    We are adding a story-and-a-half addition, with baths both up&down-stairs. I have my wet wall from the downstairs bathroom in a location which allows for the upstairs toilet to flush directly into a vertical 3" pipe, which I will vent with a 3x3x2 wye positioned approx 4-6" below the closet flange. The wye will aim for the nearby upstairs wall housing a 2" vent pipe.
    Are there reasons to not do it this way? I think the layout may work better this way, however, I don't know if it's proper. I'd just ask the inspector, but I don't want to look retarded if there is a major reason for not straight piping this toilet. My original option was to run it the normal way, with the flange connected to a closet bend connected to 3" pipe, connected to a low-heel 90 w/2" vent, connected to the vertical 3" stack. Thanks much.
  2. jadnashua
    If that 3" pipe is the vent for the bathroom downstairs, you can't use it as the drain for the upstairs bathroom without relocating the vent for the room below. You'd have to run a new vent from downstairs up above the flood plane of the highest drain connected to it from upstairs (nominally 36"+6" in a kitchen, or whatever your vanity sink height is plus 6").
  4. SteveMN
    SteveMN New Member
    Mar 9, 2009
    No, the 3" is not the drain from the downstairs toilet, I should have clarified that. The 3" was my rough-in out of the concrete slab, destined to be the drain for upstairs. It is however, the only thing on that drain. Is that a bad thing? I've read that having another fixture drain into a soil drain is good method of "washing" that drain. Nothing else drains into this 3" pipe until after it enters the slab, where the downstairs sink and laundry branch hook into it. Thanks.
  5. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Look "retarded" I say. The inspector might respect that more and even aid in giving some sound advice.
Similar Threads: Toilet plumbing
Toilet Forum discussions Plumbing Hacks Video, installing a toilet with Terry Love Jun 28, 2016
Toilet Forum discussions What I hope is a simple question about basement toilet plumbing Mar 9, 2015
Toilet Forum discussions Toilet Plumbing in Honduras Feb 20, 2014
Toilet Forum discussions Crane plumbing rear outlet toilet - need to replace wax ring Apr 17, 2013
Toilet Forum discussions Toilet plumbing Dec 7, 2012
