Toilet or Septic Problem?
Discussion in 'Toilet Forum discussions' started by MarkIW, Jan 25, 2005.
  1. MarkIW
    MarkIW New Member
    Jan 25, 2005
    A little over a year ago, I installed two Crane Economiser toilets with the power-assist flush. One toilet, in the upper level of our split-level house, has worked fine ever since. The toilet on the main level worked fine for awhile, but then acted up. It would flush, but afterwards the water level would come up to the right height and then immediately drop down to almost nothing. I re-set the toilet on a new wax ring and the problem quit for nearly a year. Then the problem returned, so I tried resetting it again without success. I thought there might be a partial blockage, but found nothing. The shower drain ties in 4' in front of the toilet and it doesn't back up. You can hear the toilet gurgle when you shower, though. Tonight I went into the crawl space under the bathroom to double-check on a blockage. When I opened the clean-out, the water just kept flowing out without stopping -- at least 30 gallons. So then I went to the clean-out at the septic tank, cracked it open, saw it was completely full and gave up. The septic tank was last pumped about 18 months ago. Ideas?
  2. Plumber2000
    Plumber2000 Plumber
    Jan 13, 2005
    Eugene, Oregon
    Check for a plugged vent.
  4. Hube
    Hube New Member
    Sep 1, 2004
    Ontario
    When you look into a septic tank they always appear to be somewhat full. Unless this is only a 'holding 'tank,I believe you have a blocked/damaged tile bed/leaching field.
  5. MarkIW
    MarkIW New Member
    Jan 25, 2005
    Checked vents, other ideas?
    The snow had melted enough to get on the roof yesterday afternoon, so I ran a snake down the vent - and the other vents and found no blockages.
    Regarding the septic field, if it was that, wouldn't there be other signs, like problems with the other toilet, with the shower, with the tub, and with the sinks?
    Any other ideas or should I call a pro? If a pro, should it be a plumber or a septic company?
    Thanks for the help!
Similar Threads: Toilet Septic
Toilet Forum discussions Low-flow toilets vs septic systems Aug 4, 2016
Toilet Forum discussions Toilet to Septic tank issues Jul 4, 2013
Toilet Forum discussions Which Low Flow toilet would be best for a septic tank? May 31, 2011
Toilet Forum discussions RTHRITIC & BLIND - need new toilet - no leaks and overflows - ON WELL & SEPTIC Aug 2, 2010
Toilet Forum discussions Does a septic tank and well water affect the type of toilet I buy? Feb 28, 2010
