Toilet noise
Discussion in 'Toilet Forum discussions' started by 2goodhearted, Jan 4, 2014.
  1. 2goodhearted
    2goodhearted New Member
    Jan 4, 2014
    San Clemente, CA
    My toilet started making a squealing noise when filling is finishing. I have taken the lid off and gently push the blue cap towards the back of the tank and it stops. What can I do to fix this or where can I get a total replacement for it. I have the one with the screw on the top. Would like to get 3 of them for the other toilets in the house.
    can privately email me at 2 goodhearted@gmail.com that would be the easiest for me. Thank you.
  2. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    I sent you an email.
    Here's what it said, for the benefit of others:
    The kind you have is not easily repaired.
    Terry recommends the Korky 528MP MaxPerformance fill valve, which is essentially-identical to the Toto TSU99A.X Universal Fill Valve which Korky makes for Toto. You can get the 528MP at Lowe's (they call it a 528MPK on Lowe's web site). It will work in any Toto. I have it in several of my Totos and it's easy to install and adjust. Down the line if you had the same symptom that you now have, all the working guts of the valve are on a little quarter-sized cap which you can just replace in 30 seconds for like $5.
    Here's the valve: http://www.lowes.com/pd_336988-868-528MPK_0__?Ntt=528mpk&UserSearch=528mpk&productId=3284948&rpp=32
    Other stores have it as well. Caveat: There are other Korky 528 fill valves (plain ol' 528 with the white cap, one with a red cap, and a 528T with a blue cap). You don't want them. You want the 528MP with the silver cap, because that one will be adjusted to the proper refill ratio (the amount of water that refills your bowl). If you don't use that one, you won't start with your bowl properly filled; it won't have refilled to the right level before the tank refill shuts off.
    There's a video on how to install the 528MP here: http://www.youtube.com/watch?v=Gw7HvHtaA84
    Good luck and come back with any more questions.
Similar Threads: Toilet noise
Toilet Forum discussions Loud Jackhammer Noise When Toilet Flushed In Morning Feb 14, 2017
Toilet Forum discussions Toilet water supply has been off a while...try to turn back on now and get a horrible loud noise... Jan 18, 2017
Toilet Forum discussions Help! Toilet makes weird noise every 3-15 seconds after hours of not being flushed Jan 11, 2017
Toilet Forum discussions Dripping noise from toilet May 28, 2016
Toilet Forum discussions Toilet Clicking Noise May 5, 2016
