toilet no flush
Discussion in 'Toilet Forum discussions' started by byrnezy, Apr 21, 2012.
  1. byrnezy
    byrnezy New Member
    Apr 21, 2012
    ottawa
    1st time here looks like a great site , hope someone can find a simple fix to this problem.
    its a new house basement rough in i have finished the bathroom every thing works fine except toilet, i can run a garden hose down toilet flange all day with the sink running as well also through 5gal out of a bucket [no gurgling or backing up at all] but when toilet is installed it just fills up bowl and will drain within 10-15min, i put a 2nd toilet on thinking i had a bad toilet but same problem the sink is 2ft away and the tub is about 2ft as well, theres a 2'' what i think is a wet vent going up from the sink, any ideas,
    thanks Mike
  2. hj
    It sounds like you installed the toilet on top of a floor drain "P" trap. If so, it will NEVER flush properly, until the trap is removed. Otherwise the system is "air bound" because of the lack of a vent, which you supply when you take the toilet off the floor and run water into the drain.
  4. jadnashua
    With the toilet off, look down the drain to see if there's any standing water...if there is, there's either a backup or there's a trap. Since it accepts water and doesn't back up, the biggest likelyhood is that there's a trap, and as HJ said, that will never work with a toilet.
  5. byrnezy
    byrnezy New Member
    Apr 21, 2012
    ottawa
    not a floor drain
    sorry for taking so long had trouble with password. it isn't a floor drain and i cant see standing water cause it has a elbow off the flange there is a sewer smell though. when i put the toilet back on i reused wax seal there was a small leak but toilet flushed when i replaced new seal we were back to no flush , it was roughed in by a big developer and i have done many basements without ever haveing a problem, could they have not vented . as i said there is no problem with sink or shower but then again there open to air right? the toilet was moved back 7'' this was done with 2 90degree elbows would this create that problem?
  6. jadnashua
    Maybe...there's a limit on how many degrees you can change the direction of a drain line without a cleanout. Plus, two of those right next to each other would likely severely slow things down. A toilet relies on the start of the flush creating a siphoning to help pull the water out of it. If it never reaches the proper velocity, it won't flush, but would drain back to the normal water height in the bowl. Put a big obstruction in the line with back to back 90's, and I think you've identified your problem.
    One of the pros will weigh in to confirm or conflict with that thought.
Similar Threads: toilet flush
Toilet Forum discussions Loud Jackhammer Noise When Toilet Flushed In Morning Tuesday at 9:49 AM
Toilet Forum discussions Toilet not flushing after flood Jan 19, 2017
Toilet Forum discussions Flushing Problem with Old Toilet Jan 18, 2017
Toilet Forum discussions Dripping Sound from Inside of Wall/Ceiling When Toilet is Flushed Jan 15, 2017
Toilet Forum discussions Wall Mounted Toilet not flushing Jan 14, 2017
