Toilet mounting question
Discussion in 'Toilet Forum discussions' started by DIY Duder, Dec 19, 2009.
  1. DIY Duder
    DIY Duder New Member
    Nov 20, 2009
    Chicago
    OK, so I wasn't able to get my Plymouth on craigslist, guy sold it, but I was able to get a NIB Dalton for $50! Sedona Biege too, looks great with this the downstairs wood panel so I'm pretty happy with that. Now when I mounted the AS Champion 4 in the upstairs bathroom to the flange (save the hate everyone) :rolleyes: I noticed that if I knock on it with a kina hard hit, like I was knocking on a door from the side hard, you could see an ever so slight ripple in the water. It's bolted down plenty tight and I'm not really that concerned about it (Should I be?), but I also noticed that none of the old 4049 AS in the house had any ripple in the bowl no matter how hard you hit it. So when I pulled up the old AS downstairs I noticed there is like a clay in the cavities around the trapway and it was like mushed to the floor. I had to scrape pretty hard to get it up. Is this something they used to use to get a better mount? :confused:
  2. Terry
    Aug 17, 2004
    We use composite plastic door shims if the floor is not level.
    Shim first if needed, then caulk the bowl to the floor with Poly Seam Seal.
    [​IMG]
    [​IMG]
  4. hj
    toilet
    It was not clay, it was plumber's putty, which we used in the 50's and 60's before wax rings were invented.
  5. DIY Duder
    Nov 20, 2009
    Chicago
    Hummmm... That's weird. Because there was an actual wax ring down too. The toilet has been down since 1962 and never removed. But there is no question there were 2 different substances.
  6. DIY Duder
    Nov 20, 2009
    Chicago
    Thanks Terry
    I didn't put down a poly seam seal since it's on the second floor. I was thinking since it's upstairs and I put in plenty of wax in the gap between the flange and the floor, if the wax ring ever failed it would leak onto the floor and I would see the water right away insted of letting it get into the subfloor and walls. Do I need to do that? :eek: Since I had a leak there before and I didn't see it untill it was in the garage I thought this might be better. Did I screw up? lol :confused:
  7. Terry
    Aug 17, 2004
    We polyseamseal to prevent water from getting under the bowl.
    It's cleaner that way.
    You would be surprised to see what little boys can get under a bowl.
    Or between the tank and bowl for that matter.
    A real good argument for one-piece toilets.
    We leave a bit of gap near the back in case the seal leaks.
Similar Threads: Toilet mounting
Toilet Forum discussions Mounting Bolts For Wall Hung Toilet Apr 3, 2013
Toilet Forum discussions Mounting a Toilet: Grout, plaster, or putty? Sep 25, 2009
Toilet Forum discussions tips for mounting wall hung toilet Jul 7, 2005
Toilet Forum discussions Toilet Flange not Flat/Level Tuesday at 2:21 PM
Toilet Forum discussions How is the toilet made the difference between 1.28 and 1.60 GPF toilet? Saturday at 9:18 PM
