I have 3 toilets. One rarely used. Another toilet-an aging eljer needs jiggling from time to time after flushing to help stop water running into bowl. Last night, I flushed it again to see if it would stop and later found that water and brown/black remnants were found in another bathroom shower with opaque water leaking under recently installed Toto Dalton toilet which I have really liked as it is a little higher and works fine.
What are my options. I got drano build up remover but haven't tried it yet. I figured I would use it in the eljer. I have thought of replacing the Eljer but not sure if that is solution and what to think about water leaking from under newer Toto and does the seal now need to be replaced there. If I consult with a plumber(not on a Sunday) what should I be looking for exactly. At the moment there is no water leaking or coming up anywhere but it has now happened twice so feel it won't resolve itself without something being done.
Thanks in advance. Linda
