I just found a leak from the fill valve of my toilet in the house we recently moved into. The PO must have doubled-up on the chlorine tablets and a gasket failed.
It went unnoticed because we had temporarily moved upstairs due to a furnace problem. I discovered it by seeing the puddle in the crawlspace going under there with the HVAC guy. A bit of a bad luck string for us.
Anyway, it's leaked through some of the floorboards below the toilet. I am looking for how to get that dried out. Do I need to pull up the tile? Do I point a fan up there? It's going to get down to 35F tonight and below freezing in the coming days. I don't know whether it's better to bundle the insulation back up in there (and trap the moisture) or let it air out as much as possible (and risk things freezing).
Advice?
Advice?
