Toilet into existing 3" PVC under concrete slab
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mc_1_2_3, Jan 4, 2013.
  1. mc_1_2_3
    mc_1_2_3 New Member
    May 22, 2008
    Biomedical Equipment Technician
    Western Pennsylvania
    Hello, getting ready to install a toilet in my basement. House is only 4 years old and I placed drains in floor when building but now we have decided to move location of the toilet in the basement. Luckily it will still be directly above the 3" PVC under the slab and there is a properly installed 2" vent that goes to the roof within 3 feet of the new location. My question is what is the best way to connect to that existing 3" PVC? Dig a large hole and use slip fittings of some kind and a long-sweep 90-tee? Is there a saddle suitable for attaching a 3" to a 3" at a 45 degree angle? I will need to leave both ends of the exisiting 3" pipe open as there is a shower up-stream from the toilet. I will have enough height for a long sweep or two 45's.
    Thanks for any suggestions.
    Mark
  2. Terry
    Aug 17, 2004
    Mission makes some shielded couplings you can use.
    A wye fitting for sure, and a vent between the toilet and the shower, so that flushing the toilet doesn't affect the shower drain.
    Also, if that 3" line serves other fixtures, a vent between also.
  4. mc_1_2_3
    mc_1_2_3 New Member
    May 22, 2008
    Thanks Terry. Yes, the vent is between the shower and the toilet. The 3" line dumps into the 4" main that goes directly to the septic tank so no fixtures after the toilet.
  5. hj
    As I stated in a previous question, just because the vent is "within 3' of the new location", that does NOT NECESSARILY mean it will function as a vent for the toilet. Proximity does NOT equal proper function or utility.
  6. mc_1_2_3
    mc_1_2_3 New Member
    May 22, 2008
    Well, no pics because its still under concrete, but, the 2" vent comes off the 3" pipe (before the toilet) with a wye fitting that is 45 degrees from horizontal then a 45 straight up the wall eventually going to the roof. Not a wet vent. I believe it will work and is to code in PA.
  7. hj
    If it comes off the pipe FROM the toilet to its connection to the main, it is a vent. If it comes off the main pipe the toilet pipe is connecting to, then it is NOTHING as far as a vent is concerned. YOU believe it will work, (then why are you asking us about it, and there can be a big gap between "what will work" and what is a proper installation), and WHO said it was to code in PA?
  8. mc_1_2_3
    mc_1_2_3 New Member
    May 22, 2008
    I have another toilet that is installed the same way this one will be. The toilet goes directly into a 3" line, the pipe from the toilet doesn't have a vent on it, but the 3" main does have a 2" line that is a lav drain/wet-vent about 2' from where the toilet connects. I guess I better call Gaurdian Inspection Services and inform them that I have a non-code installation that they permitted just four years ago. Or, perhaps you can call them and berate them? Actually there is yet another toilet installed this way also. Both flush with no problems, no bubbles, no clogs.
    Why don't you try to be helpful instead of just being a prick?
    My main question was what would be the best way to connect to a 3" line under concrete, and Terry replied with a helpful and considerate answer. Thanks Terry.
    Won't be back soon if this is a representative sample of responses from a moderator.
Similar Threads: Toilet existing
Plumbing Forum, Professional & DIY Advice rework problem with an existing toilet flange - help suggestions appreciated Apr 25, 2014
Plumbing Forum, Professional & DIY Advice Connecting New PVC Pipe Vent to Existing Cast Iron Vent Pipe in a Wall for Toilet Oct 11, 2012
Plumbing Forum, Professional & DIY Advice Hooking new toilet to stack on 1st floor, below existing bathroom Jun 20, 2007
Plumbing Forum, Professional & DIY Advice new toilet under existing bathroom... Dec 3, 2006
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
