Well my toilet seems to have a few issues:
-The reservoir/tank fills up slowly (not the toilet bowl). When you turn off the water valve and turn it back on, the tank fills up normally.
-Have to flush 2-3x to get everything down.
-Toilet leaks a very very tiny bit at the base- almost unnoticeable (this doesn't bother me, but maybe this indicates what the problem is, I don't know!)
We were going to try to replace the flapper- but our flapper thing sort of looks like a plastic plunger with a rubber seal around the base.
What does the problem sound like to you? Do I need to get a replacement fill valve kit? Would it matter which one I pick?
