Toilet flushing by itself?
Discussion in 'Toilet Forum discussions' started by jskd82, Nov 27, 2007.
  1. jskd82
    jskd82 New Member
    Nov 23, 2007
    California
    What would cause my toilet to flush by itself? I am not sure if it is a full flush but I have heard it refilling the tank a couple times already. I don't live in the home and I am hardly there so I am not sure how often it does this.
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Your flapper is leaking. Replace the flapper and it will stop refilling.
  4. gtc
    gtc New Member
    Nov 25, 2007
    Ditto.
    Shut off the water supply one night and the tank will probably be empty in the morning.
    I just had the same problem over the weekend and changed the flapper. The replacement was about $5 at Lowes. Bring your current one with you so you get right one to replace it. There were several to choose from.
  5. prashster
    prashster New Member
    Dec 7, 2005
    You shld be seeing ripples in the bowl if there's a leak from the tank into the bowl.
    I'd press the flapper down to see if it seats tightly and stops the trickle. If yes, then replace flapper. If no, cld be the flush valve needs replacing.
  6. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    The worst thing for a flapper are those drop in toilet cleaners... FYI
  7. Verdeboy
    Jun 12, 2006
    Unless you need a special kind of flapper, just buy a red Korky. It's the best of the bunch.
  8. grazzy
    grazzy New Member
    Nov 1, 2007
    Virginia
    how long do the red ones last compared relatively to the black rubber ones? i had one in an american standard that was about 3 years old and it leaked like a sieve. as soon as i replaced it with the black one, all leaking stopped. the texture of the red one still feels brand new, but it doesn't do the job. :confused:
  9. Terry
    Aug 17, 2004
    The red Korky last longer.
    And they cost more.
    I never use the black ones on repairs.
    But then I also have a box of them, so if one doesn't work, I throw it away.
  10. Verdeboy
    Jun 12, 2006
    The red ones last longer and they are not so messy to replace.
    The black flappers tend to disintegrate, and you don't want to touch one with your bare hands when you go to replace it. They stain everything they come into contact with.
Similar Threads: Toilet flushing
Toilet Forum discussions Toilet not flushing after flood Jan 19, 2017
Toilet Forum discussions Flushing Problem with Old Toilet Jan 18, 2017
Toilet Forum discussions Wall Mounted Toilet not flushing Jan 14, 2017
Toilet Forum discussions My Toto CST743E Toilet is slowly flushing less and less properly Sep 28, 2016
Toilet Forum discussions toto toilet not completely flushing Aug 9, 2016
