Toilet flush causes sink to gurgle
Discussion in 'Toilet Forum discussions' started by brianh2000, Feb 10, 2008.
  1. brianh2000
    brianh2000 New Member
    Feb 10, 2008
    Wash DC
    Just as the Title says, whenever an upstairs toilet is flushed, the kitchen sink gurgles. It also causes a gurgling sound in the upstairs bathtubs.
    Secenrio:
    Newly constructed luxury home.. 4 yrs old
    4 bathrooms..
    2 upper level
    1 main level
    1 lower level
    Changes to plumbing made:
    The lower level bathroom was installed 3 yrs ago,
    plumbling got dinged for improper venting at inspection.. corrected.
    Single bowl kitchen sink was replaced with a double bowl when Granite countertops were installed. not inspected.
    Seems the gurgling began after one of the two were completed, it became more noticable after the kitchen sink was installed.
    Any idea's????
    Forgot to mention, there is a flex PVC pipe installed under the sink with an additional elbow.
  2. Cookie
    Cookie .
    Oct 7, 2005
    While it does sound like a venting problem unfortunately, without anyone being able to look at it to see how the vents are runned, it is extremely, hard for anyone to tell you how to correct it.
  4. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    Before you open up any walls
    Double check if the vent stack isn't being abstructed by some sort of nest. If it checks out, make sure your main drain is not plugged (stranger things have happened)
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Are you in a frozen wasteland where snow could be covering the vent on the roof or, frost closure is occurring on the vent pipe?
    The newer toilets with a 3" flush valve push air and water much more forcefully than before.
    If you can extend the vent up through the roof, you should be fine. As you know now, it's not admitting air, it's giving air a place to go. You have a "positive" pressure when the new toilet is flushed.
    I see it all the time.
    The new wet venting codes were put in practice "before" the advent of the new high performance toilets.
    My guess, is that it will take years to convince some of the older plumbers that times have moved on.
    Plumbing design must take into account the new performace levels that we are seeing.
Similar Threads: Toilet flush
Toilet Forum discussions Loud Jackhammer Noise When Toilet Flushed In Morning Tuesday at 9:49 AM
Toilet Forum discussions Toilet not flushing after flood Jan 19, 2017
Toilet Forum discussions Flushing Problem with Old Toilet Jan 18, 2017
Toilet Forum discussions Dripping Sound from Inside of Wall/Ceiling When Toilet is Flushed Jan 15, 2017
Toilet Forum discussions Wall Mounted Toilet not flushing Jan 14, 2017
