I imagined a flow control device that would go between the wall valve and the toilet fill valve that wouldn't let the clogged toilet overflow for 5 hours. this device would limit any one fill cycle to say 2-3 gallons then shut off until you reset it. It would be a mechanical counter with maybe a battery powered
solenoid gate valve. I bet a 9 volt battery would run it like one those
keypad door locks. Any of you inventors up to it? If you could set it maybe it could work for dishwashers, ice makers, washers, the things that when they leak could cause a lot a damage.
That way so when young teenager clogs the toilet, starts flushing like mad breaks the flapper, then panics and runs out of the house leaving a second floor toilet overflowing this device would stop the flow.
It would stop after a few gallons, not continue overflowing for for 5 hours
until an adult returned.
