Toilet float doesn't sink!
Discussion in 'Toilet Forum discussions' started by veloria, Dec 29, 2005.
  1. veloria
    veloria New Member
    Dec 29, 2005
    About a month ago, I replaced the entire insides of my toilet because it kept giving me problems. Since, then it doesn't always refill completely. I was looking at it today and I realized that the float (not a float ball, but one that is attached to the body of the valve) is not sinking. I can push it down and it will work, but it gets stuck up again the next time around. Any suggestions on how to get this float looser?
    Thanks! :)
  2. jimbo
    jimbo Plumber
    It sounds like you are talking about a Fluidmaster 400A; check to see if it is turned so it rubs on the side of the tank.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Are you talking about the fill valve or the flapper. The flapper is what goes up when you push the handle, then it goes down.
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    float?
    I think hes talking about the ballcock.
  6. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    If it's a float-cup type refill assembly like a Fluidmaster 400A, you need to hold the float cup under water at first to get it to work properly.
    Mike
  7. hj
    400a
    That has not had to be done since the original 400's which had the open cup.
Similar Threads: Toilet float
Toilet Forum discussions Toilet - Replaced Float, Have Leaks... Sep 3, 2009
Toilet Forum discussions Toilet Float Ball Mar 18, 2009
Toilet Forum discussions Adjusting Float Ball in Toto Toilet May 8, 2005
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Yesterday at 9:53 AM
Toilet Forum discussions Icera wall-hung toilet Yesterday at 8:36 AM
