John Romain
First of all, thank you everyone for all of the great information on this forum. It's made my first bathroom renovation much less scary.
So the latest thing to fix is my toilet. The original tile that I removed was lath and cement which raised the finished height to about 1" off the subfloor. In my quick fix I used 2 layers of 1/2" Hardie board under the toilet to get to the correct height. After complaints about the toilet being to high, I'm trying to bring it level to the floor.
The flooring I'm using is 12mm and I'm ALMOST to the same height as the original floor - maybe still a 1/4" short, but I can push the flange to be level and it stays. Should I be worried about damaging the pipe if I set the toilet on this? Should I just shim the toilet a bit for some height? I'm not sure I can even lower the flange as it seems connected directly to a 90 elbow.
Thoughts?
Thoughts?
